Solid beam mounts on a 4x4 saph,worth fitting ?
Oct 14, 2008 | 09:00 PM
Or will they vibrate and cause more noise ?
Oct 14, 2008 | 09:03 PM
Mike R told me not to on a road car Kev
Oct 14, 2008 | 09:04 PM
Ok chas,poly ones then,what you got on yours pal ?
Oct 14, 2008 | 09:07 PM
I had solid mounts on my saph, put them on in 1997, apart from very slight diff whine they were fine, and it stopped tyres scraping the wheel arch liners on track, the beam moved that much on the original worn out mounts that the wheeels scraped the liners on track!
steve
I would say do the Donuts solid yes but fit a poly diff mount and not solid mount it on a road car if you want a more relaxing drive. solid diff mount just passed on too much vibration for a comfy road car IMO.Poly all round would be a decent upgrade over std
Oct 14, 2008 | 09:08 PM
solid mounts are the best suspension mod i ever did to my saff, completly changed the handling for the better, and no more noise than poly bushes.....
ive done 50k with mine with no issues at all,
Oct 14, 2008 | 09:10 PM
which ones are these any pics?
More confused than ever now!!! Got a poly bushed diff mount,but beam ones are standard.
Oct 14, 2008 | 09:12 PM
imo, for road use, a good std diff mount and solid beam mounts is the best combo
Oct 14, 2008 | 09:14 PM
My standard ones were fooked Kev, poly ones were a big upgrade on mine, but obviously can't comment on solids...
Oct 14, 2008 | 09:18 PM
Alloy beam mounts with 909 diff mount and standard ford arm bushes
= a1 set up
cheeRS stu
Oct 14, 2008 | 09:21 PM
Quote:
Originally Posted by
CharlieSaff
So are mine i think,cheers pal.
STUCOS
= a1 set up
cheeRS stu
Aye,the elusive bushes.
Oct 14, 2008 | 09:22 PM
when i launch my car i get heavy banging up and down of the rear wheels in arch,ive been told diff mount?
i have polybush kit but been lazy as fuck its been in the cupboard for a year
Oct 14, 2008 | 09:23 PM
JTECHSAFF
agreed, std diff mount (in good condition) solid beam mounts, handling is so much better and only slightly more noise than normal and i use mine every day,
get em fitted dude
Oct 14, 2008 | 09:24 PM
Who sells solid and poly ones,mike r ?
who sells solid mounts then?
I have pollys in mine which were better than standard, but i have a set of solids for when the car comes back on the road.
JTECHSAFF
yes , yes use a standard diff mount if your using solid beam mounts
if you use both you will get noise and vibration been there yrs ago
marco
Oct 14, 2008 | 09:39 PM
about 50quid on ebay dudes
Oct 14, 2008 | 09:46 PM
ive got solid beam mounts on my 2wd and im running a solid diff mount, ive driven bout 7000miles with no issues at all,
1 its made the rear end really responsive,
although the solid diff mount is a bit over kill
Sorted,got some from richie.
Oct 14, 2008 | 09:48 PM
From: Under the water.... .......in a nuclear submarine
KSA-Cossie
Glad to help Kev
Oct 14, 2008 | 09:49 PM
Cheers pal.
Oct 14, 2008 | 09:56 PM
care to tell people about the noise and vibration though dude?
Oct 14, 2008 | 09:57 PM
You will be wanting me to fit them keve
Oct 14, 2008 | 10:00 PM
10 mins a side to fit....
Oct 14, 2008 | 10:10 PM
STUCOS
You just know i aint doing them myself !! Will see if my mechanic will do them.
Oct 14, 2008 | 10:12 PM
kev, my boarder collie could fit a set of these
Oct 14, 2008 | 10:21 PM
Twellsie
Ssshhh what noise and vibration lol
well im not sure what is like with out a solid diff mount, but i get a constant whine from my diff (even though it had only done 1500miles since it was re-built)
and i suffer from back lash slightly when commin off the power, i would assume a standard mount would eliminate this?
launches r brutal but its worth it in my opinion, i suppose it depend on if you use your car as a daily driver?
ive just driven to and from the ring, n found the car really easy going,
im also running coil overs
Oct 14, 2008 | 10:34 PM
JTECHSAFF
Talented dog,mine cant take a drink without spilling it all over the place.
Oct 14, 2008 | 10:37 PM
Kev doesnt like to get his hands dirty
Oct 14, 2008 | 10:40 PM
STUCOS
Pmsl,but very true.
Oct 14, 2008 | 10:46 PM
just out of interest, the guys with the solid mounts, have you left them in bare Alum?
Oct 14, 2008 | 11:58 PM
Richie.
Glad to help Kev
Got a set of these on the focus (in gold
Feels waaaay better than my saph ever did
Oct 15, 2008 | 12:50 PM
JTECHSAFF
Blow by blow account please.
Oct 15, 2008 | 01:08 PM
marco polo
marco
Agreed. It may also cause the diff casing to crack...
Oct 15, 2008 | 01:11 PM
I do it the other way round and use Powerflex beam bushes and the alloy diff mount. Mine handles okay
Oct 15, 2008 | 03:24 PM
Resident Wrestling Legend
KSA-Cossie
remove bolts
remove bush
fit new bush
replace bolts
you don't even need to lift the car off it's wheels
Oct 15, 2008 | 03:28 PM
i've got a very good condition standard item if anyones interested
came off my 36k mile 3dr.
P.S this is not a for sale post
