no be a workin are they not. could this be due to my light/indicator stalk being faulty? i cant get any side lights but main beam works fine and indicators and hazards. checked all fuses all none blown.
wd40 all connections make sure they are contacting correctly also make sure they are wired up right
if nothing then try changing the stalk as the switch in the stalk may be broken
