cosworth wiringsapphire cosworth indicator wiring diagram
Old Oct 13, 2008 | 10:11 AM
f62try's Avatar
f62try
Default cosworth wiringsapphire cosworth indicator wiring diagram
hi al can any 1 help me im after wiring diagrams for my sapphire cosworth the hole car if pos if not ive got most of them but need the part that covers the indicators any help would b great eg a haynes manual model that covers it mine is a 2wd but is the non turbo 4x4the same ?? thanks
Old Oct 13, 2008 | 11:50 AM
jon@work's Avatar
jon@work
http://www.siipicossu.com/manuaaleja/manuaalit.htm
Old Oct 13, 2008 | 11:57 AM
f62try's Avatar
f62try
Default thanks
hello mate your a star its like hitting your head against a brick wall trying to find wiring diagrams thanks again
Old Oct 13, 2008 | 03:07 PM
Haynes manual as well, just a regular "high level" wiring loom same as ghia etc on which cossies are based, ecu loom is totally different to std though of course.
Old Oct 14, 2008 | 10:14 AM
f62try's Avatar
f62try
thanks tabetha thats what i wanted to no its the in car loom that i need to cover most iv got ecu loom abs etc just needed in car loom few little probs after a reshell thanks again she may even b back on the road this year bless her
Old Oct 14, 2008 | 11:21 AM
Good luck, just pop up any problems loads of helpful bods on here.
Old Oct 14, 2008 | 02:00 PM
jon@work's Avatar
jon@work
the Haynes manual is also on that link
DixieTheKid
Jul 23, 2023 10:16 AM
3dr cossie
11
Dec 21, 2015 03:38 PM
jdsjojo
Aug 26, 2015 10:09 PM
Aug 14, 2015 07:29 AM
