coilpack conversion on cossie
Oct 12, 2008 | 10:18 PM
ive looking to doing this for a while
ive bought a ford coilpack and leads a while back but need the other bits
anyway i recently came into an s-reg 1.6 zetec 77k escort for £65,was going to scrap it but can i use the parts off this?
Oct 12, 2008 | 10:29 PM
Don't think you can use anything from the escort? Easiest way is to phone Stu and buy the rest of the kit
Oct 12, 2008 | 10:42 PM
il ask stu as im sure my managment can run coilpack without the driver card
Oct 12, 2008 | 11:07 PM
Ahh sorry i thought you had standard weber stuff!
Oct 12, 2008 | 11:11 PM
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
What ECU you running mate?
Oct 12, 2008 | 11:13 PM
Oct 12, 2008 | 11:16 PM
Col i have all the bits coming for this conversion , so i will go test dummy again at the end of the month
Oct 12, 2008 | 11:26 PM
as usual mate lol,il give you a shot of car a week on sat see what you think
Oct 13, 2008 | 03:41 AM
I don't know for def, but would have thought the collins ecu will have built in coil drivers, so you need nothing else, apart from a bit of wiring to coilpack.
Oct 13, 2008 | 09:49 AM
What tab said.
Just get a coilpack of a scrap mondy for a fiver.
Oct 13, 2008 | 06:10 PM
cheers,i have a coilpack and leads seperate,so i just need some sort of loom not an amp or anything
Oct 13, 2008 | 06:58 PM
Col,
Does your colins ecu come with any instructions? Really need a pin out to find out where the the coil pack driver pins are.
All you do the is feed 12v to the centre of the coil and the ecu grounds the oter pins to fire it.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
SMILER258
Sep 28, 2015 09:04 AM
