Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
escort 1.8 zetec cambelt/oil recommendation?
Old Oct 10, 2008 | 11:10 PM
punto_td's Avatar
punto_td
Default escort 1.8 zetec cambelt/oil recommendation?
right the cambelt is well over due, its a 1993 1.8 zetec, are the tensioners common to fail or unknown to fail? and the guides? its done 140k and i dont know any history, should i just do the belt or is the kit worth the extra.
as well, with it on 140k what oil should i use? 5w30 still ok or should i use 10w40, and what mechanicly should i expect to fail at this mileage or is it just hit and miss.
oh also, what coolant does this take? the red stuff or blue?
Old Oct 12, 2008 | 01:05 PM
addiction's Avatar
addiction
get the complete cambelt kit mate! tensioners are known to fail! 5w30 should still be ok to use
Old Oct 15, 2008 | 07:41 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Get a full cambelt kit fella, it's a false economy not to. I would also be tempted to do the water pump while you're there.
Stick some 5w30 in and yes, just the standard anti freeze/coolant.
Old Oct 20, 2008 | 01:54 AM
I would at that mileage use 10W/40 personally, and do use it in a engine with less than 25,000 on it, the thin oils are marketed/used for economy reasons.
FlashRS
Sep 14, 2015 12:36 PM
Dubs44
Aug 21, 2015 02:42 PM
Vincereese
Aug 18, 2015 03:57 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
gingerturbo
Aug 11, 2015 09:44 PM
