Cosworth valuation?
time has come to buy a bigger place to live and I may have to part with my most loved.. Its Performance Fords old project saph cossie, spec is as below: (copied from the mag feature)
Custom Magnex 3" bore downpipe and exhaust system with 4" HKS tailpipe, Pipercross Vector RS500 induction kit, Thermotec wrapped exhaust manifold and system, Magnecor 8.5mm ignition leads, Tommy Field spec ported cylinder head, WRC head gasket, Garret -34 actuator, Turbo Dynamics hybrid turbo comprising T28 exhaust housing and wheel, T4 compressor housing and wheel, full roller bearing core, high pressure oil pump, Pace RS500 intercooler, Pace alloy rad, Samco silicone hoses, 803 (dark green) injectors, 3 bar map sensor, Bailey alloy header tank, oil separator, swirl pot and power steering tank, Tommy Field remapped ECU and Pectel WRC loom.
debadged grille with mesh, clear front indicators, Cool Louvres louvred bonnet, small front number plate, delocked doors, clear square side repeaters, debadged and delocked boot, late-spec rear lights and surround, rolled arches, headlamp wipers removed and strip replaced with GL item
Chassis Dynamics lowering springs, Bilstein Sprintline shocks, Powerflex bushes, alloy front strut brace, Collins rear axle tightening kit.
AP 4-pot front calipers, 330mm drilled front discs, EBC Greenstuff front pads, Goodridge stainless front hoses, Black Diamond cross drilled and grooved rear discs, Black Diamond rear pads, Black Diamond stainless hoses.
8x17" Azev C alloys with 215/40x17 Bridgestone S-02 tyres
front seats retrimmed in Anthracite leather and Moonstone Alcantara, matching rear seat, door cards and gear lever gaiter, Momo Race 320mm steering wheel, Momo Race Air Leather gear knob, Nomad 3-hole carbon dial surround in central air vent position holding Autometer oil pressure, oil temperature and water temperature gauges; Autometer boost gauge in Nomad A-pillar pod, Autostyle mats
358bhp @ 26psi on engine dyno, with 342lb/ft of torque
Shes only done 57K full documented history and mag featured what do you guys (and gals) value her at?
Pics at: www.fastfords.org.uk/bencos.html
cheers glen
cheers glen
whats it worth? seriously Lee im only looking to value it at present but the house means she may be on the market within the next month or so, can you private message on here? if so drop me a mail or alternatively at british_boy1@hotmail.com
Adam Graham
Sep 6, 2015 06:04 AM
