Focus 1.8 TDCI problem
Old Oct 10, 2008 | 11:50 AM
JulianHJ's Avatar
JulianHJ
Default Focus 1.8 TDCI problem
My 1.8 TDCi is having engine issues. On accelerating moderately hard (when engine is up to normal temp.) it regularly loses power, as though it is being starved of fuel, and 'kangaroos' quite violently at times. This is accompanied by a plume of smoke. The most common occurance is when accelrating up slip roads on to DCs. When this happens I can put my foot to the floor and the car will sit there juddering, as though it's being held back. I have to come right off the accelator and reapply power to restore the fault.
I've had it in to the local dealer about two months ago, who cited 'a new fuel cap' as their fix, and refused to tell me any more as it was warranty work. I drive over a dozen different Mk.1, Mk.2 and Mk.2.5 Focus 1.8 TDCi's at work, with massively different milages and have never experienced this issue in any of them.
I booked it back in to the dealer, as it's just not safe as it is. Mine's a 56-plate Mk.2 with 30k on the clock, so still under warranty.
They've had the car four day, have their master technician on it and still haven't sorted it yet! They've replace a fuel line it seems, with no luck. I've mentioned to them EGR and intake pipes, as these have been cited by owners on other forums as producing similar problems. The service desk woman says she's sure the techs would have checked those...
Anyone had/heard of similar issues, or have any idea what the problem could be?
Old Oct 10, 2008 | 05:15 PM
zvhturbo29rs's Avatar
zvhturbo29rs
Default problem
i have worked on these before mate and found alot to have cracked intercooler pipes, runs up the front of the engine.
Old Oct 10, 2008 | 05:51 PM
I would take it to a different dealer from the sounds of it, sounds like a(expensive) pump problem, but could be loads of things.
Old Oct 11, 2008 | 11:56 AM
rob-blackburn's Avatar
rob-blackburn
i work for a dealer check the fuel filter full crap air filter vac not cum off or split innter cooler or pipe ive had all these cause this fault
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
taylora1409
Aug 12, 2015 12:06 PM
