Bleeding Brakes
Old Nov 12, 2004 | 09:57 AM
BillyCabrio's Avatar
BillyCabrio
Default Bleeding Brakes
On a mk4 Escort.
How??
Mr Haynes says that i have to do the whole car, is this the case or can i just do the lines that were effected??
My safety is in your hands
Old Nov 12, 2004 | 10:40 AM
Wazzzer's Avatar
Wazzzer
All your lines were affected mate, each T piece runs one front brake and one rear brake
I'll tell you the order when I find it in a mo, but don't do it with the car jacked up or the load conpensators at the rear will think the cars loaded up all the time and chuck all the braking to the rear
Old Nov 12, 2004 | 10:50 AM
Jim Galbally's Avatar
Jim Galbally
dont worry, doing the whole car aint that hard
Old Nov 12, 2004 | 11:15 AM
TheBishMan's Avatar
TheBishMan
Oh dear, lots of work for u!!
Old Nov 12, 2004 | 11:19 AM
zvhturbo's Avatar
zvhturbo
I think the order is:
Front drivers
Rear passengers
Front passengers
Rear drivers
Matt.
P.S. Halfords one man easibleed kits are very good if your on your own, remembe to keep an eye on the resevoir as well
Old Nov 12, 2004 | 11:33 AM
BillyCabrio
Cheers all..................
Wes how the hell do i do it with all four wheels on the floor I think this could be a job for my small bestest bud................
Originally Posted by TheBishMan
Oh dear, lots of work for us mate as you know i wanna help out in anything you want me to do as i am here to help!!
Ermmmm
Oh and cheers Matt for the sequence.
Old Nov 12, 2004 | 12:29 PM
Wazzzer's Avatar
Wazzzer
I've got multi spokes so its easy
not sure of the best way to do it otherwise mate, don't know if axle stands are ok to use...
Old Nov 12, 2004 | 04:54 PM
BillyCabrio
How about jacking the back up so its in the air like the front of the car?
Old Nov 12, 2004 | 07:45 PM
BillyCabrio
BTTT any more advice??
Old Nov 12, 2004 | 07:56 PM
Uncle Henry's Avatar
Uncle Henry
you're ok doing it with the car jacked up as long as the weight is still on the suspension. ie jack it up and drop the wheels onto wood/bricks etc.
The order doesnt really matter but you are supposed to do the furthest wheel from the cylinder first and work in.
hth
Old Nov 12, 2004 | 07:59 PM
BillyCabrio
Does this order sound right to you?
Front drivers
Rear passengers
Front passengers
Rear drivers
Old Nov 12, 2004 | 08:17 PM
AndyRST's Avatar
AndyRST
Also have you got the rear load bias valves on the rear brakes ?
If so put as much weight in back / boot as you can this will open the valves up and make it easier to bleed the rear brakes and get any air out
Old Nov 12, 2004 | 08:21 PM
BillyCabrio
How much weight? Anna?
Old Nov 12, 2004 | 08:22 PM
Wazzzer's Avatar
Wazzzer
Sound advice I reckon, like Uncle Henry said the wheels must all be on the ground.
(this is why I'm paying someoen to do mine this time round )
Old Nov 12, 2004 | 08:31 PM
BillyCabrio
Christ this is going to be fun then
Old Nov 12, 2004 | 08:32 PM
AndyRST's Avatar
AndyRST
Anna's only light You need ATLEAST a set of 34F's in there to help
Old Nov 12, 2004 | 08:33 PM
AndyRST's Avatar
AndyRST
Paul infact i perfer to bleed my own too that way you know its done properly and you get a good firm pedal
Old Nov 12, 2004 | 08:34 PM
Wazzzer's Avatar
Wazzzer
I had my missus 32Gs in there to help last time
Old Nov 12, 2004 | 08:38 PM
AndyRST's Avatar
AndyRST
Any pictures to prove it Wes
Old Nov 12, 2004 | 08:43 PM
BillyCabrio
Fancy coming upto give me a hand then? We can go straight to the party after
Old Nov 12, 2004 | 09:11 PM
Wazzzer's Avatar
Wazzzer
One of her bra do?
Old Nov 12, 2004 | 09:13 PM
BillyCabrio
yeah lets see it!!
Is the above the right sequence Wes??
Old Nov 12, 2004 | 09:14 PM
AndyRST's Avatar
AndyRST
Cant paul off out m8
Wes pics of her in and out of bra will be the only accepted proof
Old Nov 12, 2004 | 09:22 PM
Wazzzer's Avatar
Wazzzer
Taken from the techical archive
Anyway here’s the correct order to bleed them all in.
Rear right
Rear left
Front right
Front left
and as for pics bear with me, I've got one of me wearnig one of her bras on my head somewhere...
Old Nov 12, 2004 | 09:29 PM
Wazzzer's Avatar
Wazzzer
I am soooooooo dead if she sees these....they are here till she comes home at 11....
she's home
Old Nov 12, 2004 | 09:31 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
PMSL
Old Nov 12, 2004 | 09:34 PM
AndyRST's Avatar
AndyRST
FPMSL
If she not home till 11 get the "proper" pics up
Old Nov 12, 2004 | 09:36 PM
BillyCabrio
Lets see them beauties!!!! Pm'em round if you like!!
Old Nov 12, 2004 | 09:39 PM
Wazzzer's Avatar
Wazzzer
lol if I had any........
I wouldn't post them up
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
