2wd saff breaking.ap/billys/mo's/200 block/reground crank etc
right the deal has been done on my new car so these parts are officially up for sale. ignore my previous post and at the moment only really what i list is for sale. ideally i need the shell left in some sort of decent state with a view to getting my private plate off in the future
i would sell the shell if a compromise is reached about the plate. its in pretty good nick
Here is shell underside resto
anyway here are the parts and i'll listen to offers on each if need be,
pic of underbonnet stuff
Compomotive MO's in black, 17". et to be confirmed tonight but they are 2wd fitment. rears are 235s but have melt spots from the rollers. pics of that to follow but rubber depth is good. fronts i think are 215s but will confirm tonight. £500
T34 Turbo with 0.48 housing. Done barely 3-4k tops. £400 - SOLD to Oliver
Shotpeened T5 gearbox. Was excellent condition when i used it and done barely any miles with me. I've driven with bad synchros and this is a dream in comparison! £350 SOLD to STUCOS
Short shift for 2wd box, nice tight gearchange, £60 - SOLD to righthooker
crank thats been recently reground to 0.25 at SCS, inc bearings. £450
Crank, think standard but needs ground £200 ono
FULL gpA engine gasket set, new. £180
2 sets standard rods, £100/set
GpA 044 pump done about 500 miles tops. £100 SOLD spoilt_rs
Green injectors. Professionally checked and cleaned by boschman and done barely 500-1000 miles since. £120 - SOLD spoilt_rs
3 bar map sensor £30 SOLD to Oliver
bailey header tank, £70 SOLD to Oliver
bailey swirl pot, £40 SOLD to Oliver
magnex exhaust with centre boxes removed and sounds excellent. fits FAR better and higher than other systems as it splits in 2 like OE. £200 ono
Radtec 500 IC, BRAND NEW, only fitted but never run. £280 SOLD to Oliver
AP CP5000 2wd kit. calipers, hoses, brackets, bells, discs. 1 caliper had a repair where bleed nipple cracked the case. professionally fixed by Philloy. discs seen better days. £450 SOLD to loader
AP CP5200 calipers, VGC, with 4x4 brackets. £350
Rear AP calipers, dont know model, 1 caliper has 1 stuck bleed screw. recently rubbed down but needs paint. £200 - PROVISONALLY SOLD Ronnie Amis
Twin AP brake bias valves £60
Hydraulic handbrake, unsure on price, £100? - PROVISONALLY SOLD Ronnie Amis
Loom, new 3yrs ago, done FA miles in car. supplied by Dingy. £300 ono
Cam cover, blue with breather take off, £70 - SOLD to trotter
Bailey breather, dont know what its worth. offers. - SOLD to trotter
Full set of water/boost hoses in blue. GGR make i think. £80 SOLD to righthooker
GpA coil £20 - SOLD to trotter
Ford motorsport Beru leads, hard to find, £50 SOLD to Oliver
Ford OUTER trailing arm bushes, BRAND NEW, rocking horse shit and deleted from ford, £150.
-31 actuator £30 SOLD to Oliver
Standard airbox with K+N filter panel £40
Smoked saff rear lights £25
Rear number plate surround from 4x4, £20
Rear abs sensors, pair of, £50
Tarcal Strut brace £100?! dont know value.
200 block, 99, original bore, melt down so needs hone/bore. £tbc
200 block cracked across head bolt, .5 bore £offers
Head fully rebuilt, brand new tappets, ground valves etc. would need to check depth. £500
2wd head, needs skim, quite low already. complete set of good valves. offers.
2wd inlet £40
2wd exhaust manifold £50
2wd flywheel £40
2wd cams £60
Mocal remote oil filter
Mocal in line oil thermostat
Mocal 19 row oil cooler with full braided lines and dash fittings. £250 the lot SOLD to STUCOS
Fully rose jointed front Bilstein coilovers. offers
Fully rose jointed rear Bilstein coilovers, 1 is leaking slightly. offers
2wd GAZ coilover kit £350 ono
Racetech oil temp/oil pressure gauge
Racetech water temp/pressure gauge
Racetech fuel pressure gauge,
Racetech boost gauge
Air/Fuel ratio gauge
GENUINE RS 500 splitter cut to fit a saff. £200.
I will accept offers accordingly.
Number is
email chopsworth@hotmail.com
would prefer cash paid direct to halifax/Bank of Scotland or cash recorded delivery. Not interested in paypal really.
Postage on top obviously.
i would sell the shell if a compromise is reached about the plate. its in pretty good nick Here is shell underside resto
2wd inlet £40
2wd flywheel £40
2wd cams £60
Number is
Just make sure before you start breaking the car the dvla dont need to inspect the
car before you can take the plate off.
I think they do it now on all cars over 15yrs old.
Its a stupid system but it needs a current mot and the car cannot be untaxed for over 12 months.
Just thought i would mention it, as i almost got caught out on my saph..
Al...
Al...
Al...
Al...
Me Cossie Runs Atlast!!!!
Right i need the following please:-
1x rubber engine mount
metal water pipe at bottom of rad
fan switch plug with about 2" of wire left on
rad mounts
circlip that holds the speedo cable to gearbox
both front kick plates
CheeRS Barry
rad mounts
CheeRS Barry
,whish i had more money chop,as there's other bits i would like
