Breaking 2wd saff
I am going to strip my saff as and when i have time.I work long hours so won't be doing it quickly.i have removed a few parts already to get the ball rolling, but am working constantly for the next two weeks so probably wont have time to remove anything else yet....but watch this space
please note i am located in sutton surrey
so far i have for sale
drilled air box with new K & N panel filter £40
i will try to get a list up of the rest of the parts asap tomorrow
i have also removed
exhaust manifold(both parts) £50
standard late spec cambelt cover with cosworth logo £25
polished lifting eyes £10
turbo damper(bailey style) £60
group A coil boxed and never used £20
polished throttle cable bracket £15
polished strutt tops £10
leather usual wear and hole on drivers bolster,
passenger side wearing,door cards very good £225
bottom end(very good no smoke,knocks or rattles at all) £750
l6 ecu with sttagee 1 chip £80
more will follow as soon as i can get outside !!
cheers
Matt
i have also removed
cheers
Matt
the shell isn't that bad, i had the inner and oute sill's welded last year but it does have a hole around the passenger side strutt top that i noticed when removing the header tank but does look like it can be mended(and yes it is the one in my sig !) it is also hpi clear with 5 previous owners !
cheers
Matt
Thats fine with me, just let me know. How much would you want for it??
the engine was totally standard spec and i have got the head off and its in for pressure testing and to make sure it's still got a straight edge before i sell it as i want to be certain all is ok. The bottom end is still in the car and was spot on with no knocks rattles or anything and can be looked over once it comes out.
prices will depend on whats with the engine.
cheers
matt
cheers
matt
cheers
Matt
cheers
Matt
Any more info/pics also
cheers.
Matt,
Whatcha doing ??
(real tears) Popped in & see your brother on Saturday but he'd left Rich to it !!
Q/Matt, if it helps I can pop over & whip the diff off as your both local tol me !!
jb
Whatcha doing ??
jb
my brother seems to take most saturdays off.......wish i could !!!!
hopefully i might do it one night this week.......i'll keep you posted, cheers for the offer you maybe getting a phonecall if i'm stuck !!
Cheers mate, I think Matt is going to give me a shout once he's got it off...
I got it from a mate in south london and it's been around here for at least 8 years but i think in the history there are some reciepts from an owner in Hertfordshire....???
I need the following please:-
1x rubber engine mount
door panel screws
metal water pipe at bottom of rad
fan switch plug with about 2" of wire left on
rad mounts
circlip that holds the speedo cable to gearbox
both front kick plates
how much with postage to bristol please
door panel screws
rad mounts
few more bits removed tonight pm if there's anything you need
p.s people that are waiting for me to get back to them with postage cost's, i should be doing this tomorrow
cheers
Matt
cheers
Matt
few more bits updated, most sstuff available.
bits will bee going on ebay in the next few days, link will follow
