con rod confusion
Old Oct 5, 2008 | 01:35 PM
juffer's Avatar
juffer
Default con rod confusion
Hi all,
I need some help with conrods for my zetec. I want to use vauxhall let pistons and eagle rods form america but as far as i understand you cant use them together due to the pin wont fit as you have to machine the hole for the pin. If this is the case what other options do i have?
Old Oct 5, 2008 | 02:05 PM
marky_g's Avatar
marky_g
Fleet Manager
pec do zetec pistons, accralite do zetec pistons, and wossner too
Old Oct 5, 2008 | 03:19 PM
juffer's Avatar
juffer
I kno these companies do the pistons but i wanted rods to suit let pistons. The reasons for using let pistons is the comp being 7.4:1 as apposed to je pistons being 9.0:1. Has anybody found rods to suite c20let pistons?
Old Oct 5, 2008 | 04:00 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Eagle rods are too long for the LET pistons (well, if you want to retain low compression!).
Farndon will do them for you and i'm sure Arrow will have a spec on file to produce you custom ones. Alternatively PEC do them, apparently. Worst case scenario with these will be to ream out the small end a bit to match the pistons.
Old Oct 5, 2008 | 04:26 PM
juffer's Avatar
juffer
do you know what the compression will be if let and eagle rods were used?
Old Oct 5, 2008 | 04:46 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Once you've machined the pistons down to give you the right deck protrusion, probably about 9.5:1
Old Oct 5, 2008 | 06:11 PM
juffer's Avatar
juffer
That compression is way too high lol. What rods does ian howell use with his let pistons?
Old Oct 5, 2008 | 06:59 PM
mk3cable's Avatar
mk3cable
that would be telling i think that he keeps that under his belt
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
little bram
Sep 27, 2015 07:45 AM
lime
Sep 25, 2015 06:56 PM
