siemens 65lb injectors. £110 posted or swap for 55lbs or 83lb
as new. the daka slim line type, look far more modern! idealy want a swap for siemens 55lb or 83lb there ideal for a 550bhp build
cheers
cheers
at a serious push mate! i wouldn't spend £100 and loads of fuel and time off work, to go on the rolling road to be told that you cant get enouth fuel to get the best out of your turbo. this happened to me with my old fuel pump!! it sucks!!
i'm going to order a msd chip and there off the shelf maps are 55lbs or 83lbs
these injectors are the right spec for my engine but i want to use a msd chip, norris motorsport do all the siemens range so does paul hills at EA i think msd do them as well but only a live map, if someone wants more power and lives near them its a perfect swap!
i have no money for a live map!
Steve Escos
Oct 1, 2015 06:57 AM
timsrs
22
Sep 24, 2015 08:14 PM
grishenko45
Sep 9, 2015 12:58 PM
