Does anyone know if the t25 on a small escort cossie uses a t25 core and if you can run any t25/28 core in the turbine housing? A/r size of turbine? Has anyone got a fooked turbo for sale?
Theirs one on Ebay @ £90 at the moment with 4 days to go.
i have a fooked t28 with 360o thrust bearing in, it came from ggr, there is no play in the shaft but it is smoking on the down rev, so i think its the turbo, i have taken it off but not fitted the new one so cant say for def.
