fitting an actuator
Old Nov 11, 2004 | 11:43 AM
Muska's Avatar
Muska
Default fitting an actuator
can anyone give me some tips on fitting a new actuator? only running standard boost and dont have a boost gauge to set it by. is it a relativly easy job or should i get a pro to do it? any help appreciated
Old Nov 11, 2004 | 11:49 AM
ballin's Avatar
ballin
you need a boost gauge mate, otherwise set it low and keep taking it up until the limiter cuts in, then back it off a tad
Old Nov 11, 2004 | 11:52 AM
Paddy's Avatar
Paddy
Legend
PMSL
Muska's Avatar
Muska
cheers mate to set it low is that rod out?
Old Nov 11, 2004 | 11:53 AM
Muska's Avatar
Muska
nice smiley paddy
anyone got any better tips? there has to be a way without a boost gauge surely?!
Old Nov 11, 2004 | 11:54 AM
Jim Galbally's Avatar
Jim Galbally
dont try n do it without a boost gauge mate...
its possible, but i wouldnt like to try
Old Nov 11, 2004 | 11:55 AM
Muska's Avatar
Muska
cheers jim, guess ill have to buy one!
Old Nov 11, 2004 | 11:56 AM
ballin's Avatar
ballin
Winding it shorter ups the boost, longer will lower it....take it that 1 turn is about 1/2 psi mate
tis a bit cowboy i know , but as long as you start low and take the boost up you cant really go wrong, and saves payin out for some garage to do it
Old Nov 11, 2004 | 12:00 PM
ballin's Avatar
ballin
even with a boost guage tho you wont get it right 1st 2nd or probably even 3rd time, sometimes you will be under and other times you will hit the limiter.
this is the same principle, you wont be able to go above 10psi so you cant do any damage thats what the limiters there for! (especially considering you are taking it up 1 psi a time etc)
Old Nov 11, 2004 | 12:14 PM
Muska's Avatar
Muska
true, does it cut the engine or cut the boost tho?
Old Nov 11, 2004 | 12:51 PM
Paddy's Avatar
Paddy
Legend
when I first got my RS, it was hitting past the boost limiter and the engine was cutting out mate. but that was only the tip of the iceberg of my problems....
I think it does cut the lot out though for a sec ????
bodge-it ballin will know
P.S. he knows I'm only joking
Old Nov 11, 2004 | 01:07 PM
Jim Galbally
ballin, i see what youre' suggesting and where you're coming from. but its still not something i'd reccomend others do.
i tried the same thing on my 1st TT (trying to hit boost limiter)... ...the engine fucked up
Old Nov 11, 2004 | 01:37 PM
Muska's Avatar
Muska
ill definately wait then and see if karl can set it for me. cheers for the replys to everyone
Old Nov 11, 2004 | 01:58 PM
ballin's Avatar
ballin
haha fair play each to their own! any tuner who sets the boost tho will hit the limiter, thats the only way of knowing you've gone too far when you are playing around with less than 1psi or so!
when mine was done we went for 10psi on the gauge, but occasionally on hills or colder days it would cut out, so we backed it down a turn.
no damage done at all
blackbeautyzetec
Aug 29, 2015 02:11 PM
jay030787
Aug 17, 2015 06:16 PM
