turbo oil return pipe
the oil return pipe on my erst is really close to the exhaust
and keeps melting through so i was just wondering if
anybody knows what i might be able to use that would
hold up to the heat,its getting a bit annoying now as ive
changed it 3 times in the last month and a half,anybody got any suggestions please
its only a short pipe to the block but the turbo is off a saab
and everything was positioned different so i had to modify
the pipe to clear the exhaust manifold,if i put sum of that braiding
cover on the pipe would that help protect the pipe a bit
oh right,the pipe that was on it when i took the old turbo off
was just what looked like a piece of water pipe,can you i the
pipe from ford then or would i be able to get it from somewhere
else
else
Oct 9, 2015 07:38 PM
andy130
Oct 2, 2015 08:48 PM
Matt Baxter
Sep 16, 2015 08:30 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
