Anyone Interested in these parts?
I'm in the thinking process of changing my spec of my escort cosworth,
heres the parts i will be selling if i do, plz pm me if your interested and want to make an offer
Omex 600ecu with cosworth wiring loom mapped to a 400bhp spec, just been bench tested by omex, and they found theres a problem with the idle valve control circuit, but everything else is fine!
Bassically just needs a seperate rs turbo idle control valve connected to a vacum pipe and wired off the ignition. £400
36-1 crank pulley and sensor prov sold
Escort small turbo manifold with sensors and fuel rail. offers
Escort cos, small turbo map sensor £15. edis unit £15
seimens 65lb blacks 500bhp+ £100
tt38 turbo been rebuilt 6months ago. maykeep not sure at the min
Pace Escort cos charge cooler kit, needs a new pump which are £50 off ebay £100
Chrome header tank by spec r with level indecator glass on the side.
on ebay in a hour or so will add link later
Aircon pump, rad etc, pressure tank. £60
The spec i will be wanting is l8ecu with pectel baby msd 400bhp closed loom chip with wasted spark circuit, 4x4 loom, 83lb injectors, 4x4 inlet complete with fuel rail, t34 stage 3 with 63housing turbo, big turbo crank pulley, distrubter housing, 500cooler.
I want a simple 380bhp build i would be willing do do exchanges on parts and cash
cheers
cheers
