FAO JesseT/Garage19
Old Nov 11, 2004 | 09:52 AM
PhilM's Avatar
PhilM
PassionBMW.com Member
Default FAO JesseT/Garage19
Jesse.....did you say you had a small turbo escort cossie map for the MS ecu mate??
Was thinking about Garage19s situation last night, and a small turbo escort cos map would probbaly be a good start, same capacity, similarish size turbos, similar size injectors etc
Would imagine it'd get his car started, running and be a good base for tuning.
Old Nov 11, 2004 | 11:02 AM
JesseT's Avatar
JesseT
No, not a fuel map. Stu's live mapping tutorial had an ignition map which supposedly was a small turbo cossie standard map. (if read between the lines.)
MikeyRobbo
Jan 29, 2012 07:03 PM
Chris S
Jan 4, 2007 07:11 PM
Disabled Account
14
Oct 25, 2005 06:55 AM
Disabled Account
Jun 14, 2005 06:17 PM
