whats needed for a 230bhp rst?
Old Sep 29, 2008 | 09:52 PM
rst in breaking's Avatar
rst in breaking
Default whats needed for a 230bhp rst?
ive got a frst head and block to build up, emerald management, 340cc injectors, grs. im guessing the head is the restrictive link? i would be needing arp rod bolts too id imagine and poss solid lifters? cheers
Old Sep 29, 2008 | 09:55 PM
Jim Galbally's Avatar
Jim Galbally
you dont have emerald magement... lol
OFAB, beiges, 3bar, chip, job done
Old Sep 29, 2008 | 09:57 PM
rst in breaking
oh yes i do, toms going l8 so we both have management now and my injectors flow well so i thought 230ish bhp if it aint too much work required?
Old Sep 29, 2008 | 10:05 PM
rst in breaking
beiges dont flow 230 though if im correct?
Old Sep 29, 2008 | 10:07 PM
Rab's Avatar
Rab
Fucking superstar........
Deeper pockets than you think. Stick to 175bhp and concentrate on handling/braking.
Old Sep 29, 2008 | 10:11 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
What turbo you on Paul ??
Need a decent cam kit, not solids for 230. Lightened & balanced bottom end so it rev's nice, ARP big end bolts etc & you should be there with a decent amount of boost !!
Beige run up to about 215 if I remember correctly on standard fuel pressure !?!?
jb
Old Sep 29, 2008 | 10:22 PM
rst in breaking
jb
im undecided on turbo at the min, probally t3.48? (cossie t3 if im right?)
Old Sep 29, 2008 | 10:24 PM
rst in breaking
it doesnt handle too bad tbh, im after cossie brakes as have no brakes what so ever atm lol
Old Sep 30, 2008 | 06:11 AM
Rab's Avatar
Rab
I mean't, do a bit more that the usual Konis and springs......
Spend the money you'd waste chasing power on some REAL suspension mods... Like adjustable lower arms, an adjustable rear end, better ARBs etc etc.
That way later, when you've given Jim all your money for a while and you're even you can up the power on your escort and your chassis will be ready. MOst fun I ever had in an RST was a very simple chipped one, with a bigger intercooler and exhuast, but alot of work done on the suspension!
Old Sep 30, 2008 | 06:23 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Low compression engine
Big valve head
Big T3
Good intercooler
Good tuner
That's about it!
Old Sep 30, 2008 | 06:26 AM
rst in breaking
sounds good, im already settled with jim thats why i want the car back on the road.
car is already polybushed, s1 roll bar, coilovers and just had a full alignment set up which will need checking with the diff engine in though and ive got most of the bits to build it
Old Sep 30, 2008 | 09:49 AM
BillyCabrio's Avatar
BillyCabrio
Is this still your red Mk3 Paulie?
Old Sep 30, 2008 | 09:58 AM
rsdene's Avatar
rsdene
my brother has a s2 with bog standard engine bar; T2 cam kit recon t3, made 210bhp setup by Jamsport
Old Sep 30, 2008 | 03:53 PM
rst in breaking
yes paul, i kept the shell, coilovers and adjustable arms so il build a little cvh up then see how it goes and track it, whilst saving for a nice mk1
Old Sep 30, 2008 | 05:06 PM
spookie's Avatar
spookie
ŁŁŁŁ`s
Old Sep 30, 2008 | 05:45 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
as you've got management, why not use a zetec? It'd be cheaper and more reliable than the old cvh!
Old Sep 30, 2008 | 06:23 PM
Rab's Avatar
Rab
Let me compose myself a moment.....
Thats better....
Ask Jim G why he's not gone Zetec
Old Sep 30, 2008 | 10:37 PM
rst in breaking
lol, i dont want to go to that extent again as my old zetec cost me ŁŁŁŁ's tbh even if i had a 200bhp fiesta turbo lump id be happy now just to have the car back on the road and enjoying it
Old Sep 30, 2008 | 10:38 PM
Ellie's Avatar
Ellie
RAC membership
Old Oct 1, 2008 | 07:32 AM
rst in breaking
Originally Posted by Ellie_Cabrio
RAC membership
all my mates normally broke on cvh is gearboxes which i have taken care of , i think with arp's poss and a decent setup it should be fine, it shouldnt run lean as i have better 340cc injectors
Old Oct 1, 2008 | 08:49 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Big valve head for 230bhp? You really think thats necessary?
Old Oct 1, 2008 | 08:53 AM
Oranoco's Avatar
Oranoco
260bhp on my head with standard valve sizes says other wise.
My brother was running at 211bhp on beiges on his FRST. I wouldn't go just chasing a figure though I'd rather have an engine that drives well with a nice gob of torque. I mean will you get the hump if you only get 225bhp?
Old Oct 1, 2008 | 09:57 AM
rst in breaking
to be honest i wouldnt get the hump at 200bhp just to have the car driving again, i just thought whilst its apart id see whats required to make that kind of power, what boost can be run on standard engine with arp rod bolts, grs and a stage 3 t3? if i could get 20psi id be happy, i could be being optimistic but i dont know as i dont play with the cvh normally
Old Oct 1, 2008 | 10:05 AM
Oranoco's Avatar
Oranoco
My bro's was peaking at 21psi and holding 18psi iirc and that was on a totally stock bottom end that hadn't been apart in 80k miles.
In fact the only reason it came apart was because my brother had it out whilst sorting a couple of rusty bits and thought he might as well get it apart and freshen it up to standard spec (Oh how intentions change )
Old Oct 1, 2008 | 11:05 AM
DanRSturbo's Avatar
DanRSturbo
Andy RST's was 227 on standard engine
It was a 1.9 tho
Old Oct 1, 2008 | 01:23 PM
m_nettleship's Avatar
m_nettleship
about 23psi bigger turbo, thats wont be far short.
and the obvious inj etc. I allways thought cvh didnt like reving that mutch though do they.
Old Oct 1, 2008 | 02:23 PM
brizie's Avatar
brizie
Whats the next jump up in injectors after beiges are maxed out?
Old Oct 1, 2008 | 02:41 PM
Oranoco's Avatar
Oranoco
No ide to be honest. But at the very least you'll need a chip written to match the new injectors or all sorts of problems could occur
Old Oct 1, 2008 | 02:45 PM
crazycage's Avatar
crazycage
he said hes on omex. no it doesnt it says emerald lol
Old Oct 1, 2008 | 05:34 PM
Oranoco's Avatar
Oranoco
Missed that bit sorry. Been browsing the net whilst painting the kitchen
Billy_RS
16
Oct 11, 2025 09:41 PM
Chas
Sep 21, 2015 08:57 PM
A.t.p
Aug 15, 2015 11:37 AM
col93saphcos
Aug 7, 2015 03:21 PM
dlwarrior
Aug 5, 2015 10:19 AM
