t reg focus cutting out
Old Sep 29, 2008 | 07:10 AM
wimble's Avatar
wimble
Default t reg focus cutting out
starts and drives fine but the engine will just cut out for no reason
it dosent matter if it is hot or cold
canged the coilpack as they are a known proplem apparently
eney help would be great
Old Sep 29, 2008 | 09:54 AM
siward's Avatar
siward
Airflow meter? I know zetecs suffer with these.
Si
Old Sep 29, 2008 | 12:02 PM
Try cleaning the idle speed control valve out with brake cleaner and then use some WD40 to lube it up.
Old Sep 29, 2008 | 06:14 PM
wimble's Avatar
wimble
will try thanks bud
i allso found a breather pipe at the back of the engine that collapses when you start the engine
so i have orderd a new one
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
stevierob
Sep 7, 2015 07:09 PM
hopper350
Sep 4, 2015 12:53 AM
