clunking noise from underneath
Old Sep 28, 2008 | 11:54 AM
Kam B's Avatar
Kam B
Default clunking noise from underneath
Hi guys, bit of a wierd one, my car clunks when its warm and in gear under acceleration and de acceleration but not much when it coasts..first of all i thought something was loose so i had a look, then i took it on ramps to look underneath and everythings tight including the drive shaft, strut all looks ok. THe noise comes from the front right, i cant think of anything else apart fron driveshaft or even gearbox?!? the car drives fine like normal and the noise comes in like a complete revolution, again backwards or forwards
can any one shed any light
Old Sep 28, 2008 | 01:50 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
engine mounts, gearbox mounts?
Old Sep 28, 2008 | 02:14 PM
mark2's Avatar
mark2
get it back on the ramps and get the socket set out and make sure everythink is tight dont rely on looking and feel
i had a gearbox changed in a garage and they left the 2 bolts at the back of the cradle loose and that clanged a bit but not straightaway and they got a right going over when i returned
so give it the once over and check mounts with a pry bar look for cracked rubbers also pop the bonnet up put handbrake on and try pulling away in first and see if you get much engine movement doit harshish on and off the clutch and see if it clonks
might sound stupid but have you checked the wheelbearings and cv joints do a circle in the car park on full lock either way
mark2
Old Sep 28, 2008 | 02:47 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
it will be a mount or suspension arm bush
Old Sep 28, 2008 | 06:27 PM
Kam B's Avatar
Kam B
thanks for the advice
took it out today and i got nothing always the case, i shall see tomorrow
i checked the engine mounts etc they seemed ok
Old Sep 29, 2008 | 09:41 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
exhaust downpipe hitting the shell
Old Sep 29, 2008 | 10:56 AM
Kam B's Avatar
Kam B
well i gave it a good run last night and i mean a good run and got nothing, moved the car this morning and nothing
Nov 1, 2015 06:53 PM
gingeRS
17
Oct 2, 2015 09:42 AM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
talon1
Sep 15, 2015 10:27 AM
