2wd sapphire front arms
where can you buy new arms , i put on new arms from a 1600 sierra but handling is all over the place, so i take it they must be different
On pattern ones they are the same, cos 2wd(sapph) and normal 2wd, but gen ford ones use a stronger joint for the cossie ones.
I always use pattern ones never a problem. only last about 2/3 years though.
that might be your problem
Why would arms that are not made by ford be shite.
Name 1 manufacturer that does not BUY IN BITS ?
I have used QH stuff for years including TCA's on my cossie without a problem.
The point is someone makes them for ford, ford don't make them, they are not a big enough concern to do that, they do the same as any and every other maker.
so Tabetha, why don't you just go along spouting the usual shite that you do
these are 3 door/normal sierra type fitments with the nut on the top
these are saph (2 and 4wd) and escos versions with the pinch bolt on the hub
Me Cossie Runs Atlast!!!!
This is the exact pair of arms i got from my factors today, shockin bushes for the anti roll bar!!!!! Will defo be going poly LOL. Compaired to ford arm, they are VERY slightly thinner, and the ball joint is about 3-5mm smaller diameter. That is it, i am gonna carry on using them
i was having this bush conversation with the local mot tester round the corner and i said to him that the granada he had on the ramp was almost certainly bound to be failing on them and he said "sure will, i'll charge twice as much to fit th epolys if he wants them or the normal rate to fit the ford ones, which fail in about 3 weeks"
I need a set of the 2wd saphire arms also . I would like new ones but I live in the U.S.A.
Any body know where I can order new ones frrom that will ship over here . Should I try and get guine Ford parts , this car is going to see some track use . Or will after market arms be ok .
I managed to get hold of a pair of QH arms on eBay a couple of days ago. The seller only got one side for sale but a friend of his had a motor factory who could sort out the other side as well. Let's hope they will do it's job
155lee
Aug 14, 2015 11:21 AM
