dash
Old Sep 26, 2008 | 04:17 PM
nobbie_b's Avatar
nobbie_b
Default dash
alright guys part of my dash started working the other day and now stoped again its the part that shows you if the doors are open and the fuel light i think it could be the earth for it, i want to try and find out were the earth for this part of the dash is so i can run another one
Old Sep 26, 2008 | 06:53 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Try reseating the multiplug on the ECU that controls it first - behind the kick panels on either the passenger or drivers side (I forget which). Mine was telling me that the doors were opening in sequence while I was driving - reseating the connector worked for me.
Old Sep 28, 2008 | 08:45 PM
gaz4x4cos's Avatar
gaz4x4cos
think the module is the box that mounted on drivers side behind the pulldowm cubby hole on drivers side ,i only found out when i moved mine when i had bottom off dash out to do column bush , put ignition on no warning lights , gave it a knock n wiggle and hey presto worked again just a dodgy connection .
hope this helps .
cheers gaz .
Fordmad!
Sep 29, 2015 07:03 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
imnoteasy
Sep 7, 2015 09:26 PM
