Azev A's on a saph cossie
Old Sep 25, 2008 | 12:02 PM
carlo's Avatar
carlo
Default Azev A's on a saph cossie
I have azev A's on my saph i bought brembo 4 pot's off loader on here with 330 mm discs.The asevs are hitting the caliper & there is already a 8mm spacer there.Has anyone had this prob with the azev's? loaders wheels didnt touch the calipers.A mate had the same probs with his golf with azev's & ap brake kit,he ended up selling the wheels i really dont want to.
If i use wheel studs that are much longer the centre caps wont go on.
Old Sep 25, 2008 | 12:21 PM
rapidcossie's Avatar
rapidcossie
get some comps!
Old Sep 25, 2008 | 12:24 PM
carlo's Avatar
carlo
I like the azev's euan soooo much
Old Sep 25, 2008 | 12:25 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
How much more spacing do they need!!!??
Perhaps get some 10-15mm hubcentric spacers instead if you can still get clearance on the arches with these on.
Surely the studs arent going to be an issue because if you get longer ones the larger spacers will take up the difference so the end of the stud wont vary - unless of course you get 10mm larger studs & 5mm spacers!??
Also I believe that you need to get 6-7 full turns on the wheel bolts when tightening as a safe guide if this helps you?
rapidcossie
nah get some gold 18" six spokes!
Old Sep 25, 2008 | 12:26 PM
carlo's Avatar
carlo
I will need to check just how much i can get away with but when finger tight the wheel is jummed against the caliper..
Old Sep 25, 2008 | 12:30 PM
carlo's Avatar
carlo
Not into white & gold euan, i do like the 18' new style ones that were on a white saph with the chrome roll cage ect it looked really good but cant be bothered with rubbing & could do with the 1 odd grand for other things
Old Sep 25, 2008 | 12:56 PM
Stoo's Avatar
Stoo
I had to use spacers with my Azev A's on the EsCoss when I put the AP's on mate.
Old Sep 25, 2008 | 01:06 PM
carlo's Avatar
carlo
I will see what andrews got laying around for it stoo
Old Sep 25, 2008 | 06:58 PM
col cos1's Avatar
col cos1
really like azev a`s carlo they suit a saph spot on mate
personally i dont like the idea of spacers on a car that does that sort of speed
Old Sep 25, 2008 | 07:36 PM
carlo's Avatar
carlo
I know colin thats what im thinking ,
Old Sep 25, 2008 | 07:37 PM
indycos's Avatar
indycos
helooooo!!!
even though its been seen before, we need pics
3FRD's Avatar
3FRD
Azevs look awesome!
Old Sep 25, 2008 | 07:42 PM
carlo's Avatar
carlo
Cant get pics till i get the fooking thing going its in a million bits, fitted the ryan loom tonight top bit of kit nice one mate, brakes are fitted just need blead, got stack wideband to be fitted & started stripping the stupid turbo timer out.andrews still got the head skimming it ect,secs monitor is hopefully coming 2 moro(ryan done a take off in the loom for it ) the list goes on & the bank balance is going down rapid
Old Sep 25, 2008 | 08:52 PM
Csm's Avatar
Csm
Fuckin hell your certainly spending the wonga on it already
But least its all the right bits n pieces for reliability .....loom etc
Old Sep 25, 2008 | 09:08 PM
carlo's Avatar
carlo
Thats it mate im putting everything on it for it to be reliable if it went bad missfires ect i would just get fed up & want rid of it
Old Sep 25, 2008 | 09:32 PM
fordsportjay's Avatar
fordsportjay
surely you are going to come across arch issues arent you if you space them any more?i agree it looks great on the azev's.sell the brakes!
sounds like its going to be mega when finished mate.just make sure you use it and enjoy....
Old Sep 25, 2008 | 09:45 PM
carlo's Avatar
carlo
The front arches have been trimmed previously jay im hoping it will be ok im sure i will sort something out..& i will enjoy this one my garage at my own huse will be ready in a few weeks so will be easier to use
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
