Mechanical people? overheating zetec escort
my old mans just come home with steam coming out the bonnet, and the temp gauge in the red, and the engine started pinking.
Had a look under the bonnet, theres no water in the radiator tank, and the fan wasnt on either.
Theres no mess on the engine.
What we think?
What we think?
I think you've been messin with your dads escort
Serious tho, take the thermostat out, fill with coolant. Only fill with warm coolant if the engine is still hot. Or leave till cooled (say 2 hrs to be safe)
Well ive dropped him back at work so it will be sat on the drive now for a while.
Hes had nothing but shit luck with this car, it overheated about 10months ago aswell only he didnt stop soon enough and buggered the engine, so we had a new one put in...... and now this happens
I left fords about 10months ago, i think ill be advising my dad does the same
I already said we know nothing about engines.
If you havent got anything helpful to say then dont reply please
Plus the temp gauge was registering, i think if the head was gone already the gauge wouldnt even read?
No i meant from our house as in coming TO IT, sorry.
So it had done probably 4-5 miles THEN noticed the temp gauge getting into the red 1 min from the house, then switched it straight off.
As far as were both concerned the cars levels were fine prior to this because he does regular checks, and it goes for 2 services per year so its not like something was hanging off/ broken for a while.
I'd personally say head gasket mate.
If the expansion bottle is empty & no signs of an external leak (water/coolent on floor, round engine etc) then it's gotta be goin somewhere, is the exhaust smoking ??
Things it could be...........
Headgasket
expansion bottle cap
thermostat
blockage
heater matrix
water pump
things to check..........
radiator hot all over ??
when refilled with coolent can you see the water swirling in the expansion bottle, water coming out the overflow into the bottle if fitted ??
Oil (looking for Mayo)
coolent (lookin for oil deposits etc)
Top rad hose gettin hot ??
Temp sensor wire snapped ?? (wouldn't explain coolent lose tho)
drivers/passengers footwell for damp/wet.
Fans operating when run up to temp (switch connected ?)
I'd say it's probably done the head gasket now tho regardless if it has overheated !!
Good luck
jb
Headgasket
thermostat
blockage
heater matrix
water pump
Good luck
jb
If its boiled up to that extent (in 4 - 5 miles)i would say either a water pump failure - or head gasket failure.
Either way, fill it up and start it from cold and see if its pressurising the water hoses etc etc
Ill have a look but thats all i can do at the end of the day, so it will likely have to be taken up the road to the garage but after reading some of your comments i dont even want to start it let alone drive it
Thanks for the replys guys
Just looked under the bonnet and took the filler cap off and check the dipstick, both are squeaky clean.
We filled the coolant up but it was going down slightly as i was filling it, so we filled it then he just took it up the road for the guys at the garage to look at, its only 2miles so fingers crossed, ive had no phone call yet
It started fine, sounded fine so we'll see
Billy_RS
16
Oct 11, 2025 09:41 PM
