engine converstion electricans please help
Old Sep 24, 2008 | 09:43 PM
tooly80's Avatar
tooly80
tooly80
Default engine converstion electricans please help
me and a few of me mates have put an S reg 1.8 escort gti engine in a van we had a few small problems but it werent to bad until now, we are having trouble getting it runing.we have fuel but no spark and we think its the immobiliser on the engine. could anybody help me please and tel me how i can bypass it. we dont have the donor car just the engine and loom.
Old Sep 24, 2008 | 10:10 PM
tooly80's Avatar
tooly80
tooly80
is there any electricians that can help me.
Old Sep 24, 2008 | 10:56 PM
RAT8OY's Avatar
RAT8OY
I am not an electrician but I do no its tied into alsorts and I do not believe there is a quick fix connect these two wire type solution.
Might be better getting a good willing auto electrician to look at it. What about the original key from the donor? Have you thought of that as a solution?
Old Sep 25, 2008 | 08:16 AM
D200RST's Avatar
D200RST
You will need the original key as it has a chip in it. Do you have the donor car? If so it will make it a lot easier!
Old Sep 25, 2008 | 03:18 PM
tooly80's Avatar
tooly80
tooly80
no donor car just engine and loom. can anybody else help me please.
Old Sep 25, 2008 | 07:06 PM
johnnysash's Avatar
johnnysash
i think this car will have "pats" (passive anti theft system). making it a right pain in the arse! one solution would be to get a loom and manifold from an earlier car..... like an rs1800 fiesta i think these had a better ecu and throttle body as well
Old Sep 25, 2008 | 11:49 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
iirc you'll need the original PATS key and the little doodah that clips around the ignition barrel. As said above, get an early Non pats ecu, not sure on the coding, I think its DUDE or something like that
Old Sep 26, 2008 | 08:28 PM
Zetecfiesta's Avatar
Zetecfiesta
PATS will screw you over, jus spoken to my mate for you whos an auto electrician he says its a right pain to bypass as well but will give me some details over the weekend and i will send em over to you.
Old Sep 26, 2008 | 10:27 PM
tooly80's Avatar
tooly80
tooly80
thanks mate that will be a very big help.
Old Sep 29, 2008 | 09:13 PM
Zetecfiesta
he said you have got 2 options really 1 is find an early non pats ecu, or 2 find another escort gti and get the matching key and ecu, you can then get the little red chip out of the new key and fit it to your existing key for your actual car.
those are the easier options although he said there is a way round by adjusting some wires that come from the pats box which i think is in the drivers footwell kick panel or he seems to remember a company that will come and turn off the pats on the car but he couldnt remember where they were based, will ask him for more info tomoz see if he can think of owt. hth a lil bit
Old Oct 2, 2008 | 04:04 PM
tooly80's Avatar
tooly80
tooly80
cheers mate that would sound.
Old Oct 3, 2008 | 07:42 PM
Zetecfiesta
ive asked him but hes swammpd at the mo if i keep askin he may come up wit summit!!
Old Oct 4, 2008 | 10:32 AM
tooly80's Avatar
tooly80
tooly80
cheers mate much apperciated.
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
