what ecu is this..........
Sep 24, 2008 | 06:37 PM
Sep 24, 2008 | 06:42 PM
According the to the sticker, it is L8 ECU mate, with a pectel board inside. Issue no.3 also.
Sep 24, 2008 | 06:57 PM
what is the pectel board and issue 3 mean?? what injectors will it before?
Sep 24, 2008 | 07:07 PM
As above mine looks EXACTLY like that and mine is a L8 with Pectal Baby Board
Sep 24, 2008 | 07:12 PM
defo l8 early model non cat
Sep 24, 2008 | 07:51 PM
is this a pectel baby board? what injectors will it before??
Sep 24, 2008 | 08:19 PM
Quote:
Originally Posted by
B13 JUS
Depends on the chip in it mate.
Sep 24, 2008 | 08:55 PM
Strange there isn't any sticker on the chip tho. With UVs it might have erased the chip content already.
Sep 24, 2008 | 08:59 PM
would this be worth keeping?? i want to run about 450bhp and also have a level 6 ecu.
whats best??
Sep 24, 2008 | 09:00 PM
Mad Matt
is the 1 on the right the chip??
Sep 24, 2008 | 09:17 PM
Deffo run that over your L6. I'd get a new chip though just to be sure.
Whats your spec?
Sep 25, 2008 | 07:40 AM
Shorty
Whats your spec?
i have a l6 engine loom what would i need to change?? tps? what about the knock sensor? will i need to use a 4x4 loom??
Sep 25, 2008 | 08:23 AM
no just either use a 4x4 tps or swap the out wires round on the 2wd tps
Sep 25, 2008 | 09:25 AM
Jay.
Bear in mind if you use the PF01 the engine wont run properly as its a bodge.
Sep 25, 2008 | 11:10 AM
yes i forgot ! actually i need a pf01 got aprice stu ?
Sep 25, 2008 | 11:50 AM
Jay.
NLA. Sorry pal.
Sep 25, 2008 | 01:14 PM
Im I right in thinking a pf 1 is a 4x4 tps??
steve
Sep 25, 2008 | 01:32 PM
the youth
steve
i think pf 1 is 2wd and pf 09 is 4x4. sure 100% though
Sep 25, 2008 | 01:34 PM
B13 JUS
Correct.
Sep 25, 2008 | 01:50 PM
B13 JUS
cheers, my bad i actually meant is the pf01 the 2wd version. just got mixed up in my confusion..
steve
Sep 25, 2008 | 02:37 PM
Red ones are PF01 2wd
Black ones are PF09 4wd
I think they also made some PF01 in black to confuse matters
Either way it will be marked on it
I use L8 with MSD chip,coilpack and closed loop
Paul
Sep 25, 2008 | 03:49 PM
jay if you still need a pf01 ive got three of them pm me?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
