53 fiesta 1.4 cambelt problem
Old Sep 24, 2008 | 04:29 PM
Tank Mike's Avatar
Tank Mike
Default 53 fiesta 1.4 cambelt problem
Basicly I have just fitted a new cambelt and tentoir to a little 1.4 fiesta.
I stipped it out monday and it has been sitting with the engine on the piss till today when the bits came. i locked the crank with the pin and took off the rocker cover and put the plate in the end of the cams,
i've just fitted the new cambelt and tryed to start it and it will not start and the engine turns over very very fast got a good sign i fooking shit myslef. so i re pinned the crank and took the rocker cover back off and the plate slides straght back in. witch means its all timed up????
im very confused? does anyone have any ideas what the hell could be wrong with it and why it ran perfecly on monday but refuses to start and turns over fast today???
any help greaty appreshated
mike
Old Sep 24, 2008 | 06:25 PM
Tank Mike's Avatar
Tank Mike
bttt
Old Sep 24, 2008 | 06:34 PM
coco16i's Avatar
coco16i
Are you sure the crank didnt turn after you fitted the new belt as its all held together by the crankshaft bolt.... with the new belt on and tensioned you can still turn the crank even with the locating pin in and the plate holding the cams as its the crank outer pulley that locks up against the inner crank gear ( the one that drives the cambelt ) and holds them all in place.... if you know what i mean !!! Its all because there is no keyway on the crank and the inner crank pulley runs freely !
Does sound like bent valves though if its turning over quickly and not firing
Old Sep 24, 2008 | 06:44 PM
cosworthlee's Avatar
cosworthlee
how does the crank lock do u have to turn it untill it hits the web of the crank if so did u turn it clock wise or anti clockwise as this can make a difference do u have a cambelt book
Tank Mike's Avatar
Tank Mike
sure, even after it span over quickly i put the locking pin and plate back in the engine and they line up, thats what i can't understand
Old Sep 24, 2008 | 07:14 PM
cosworthlee
have u checked when pin is in if the engine is on tdc wip a plug out and check it just rules out a nother thing asumming you have timed it up corectly retrace you steps have you nocked crankshaft sensor or camshaft sensor have u got a scanner ecu fault codes may point u in the right direction
Old Sep 25, 2008 | 07:00 AM
James's Avatar
James
my mate did similair, did compression check after checkking timing which was ok and found no compression, despite having the engine running five mins ago.
took head off and found 16 bent valves, all replaced & lapped in but now it smokes, head off and got it checked, had valve seats cut in properly and another new set of valve seals and it still smokes. now it's having a new bottom end as we suspect a broken ring where the valves made contact!
rex647
Mar 6, 2022 06:20 AM
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
28
Sep 8, 2015 07:10 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
routemaster
Sep 7, 2015 05:27 PM
