What is the name of this part ?
Sep 24, 2008 | 05:03 AM
Hi,
What is the name of this part, in english ?
Where can I found it ?
Have you indication or tip of engine block modification ?
Thanks by advance.
Claude
Sep 24, 2008 | 06:04 AM
Its a oil spray jet, found on small turbo 200 blocks, you should be able to get a machine shop to modify your block.
Steve
Sep 24, 2008 | 07:09 AM
Quote:
Originally Posted by
Moonstone Steve
Steve
Hi Steve, thanks for response.
Do you know if it is still available on Ford dealer ?
Regards.
Claude
Sep 24, 2008 | 07:35 AM
not sure about ford, but mountune sell it!
Sep 24, 2008 | 10:03 AM
Quite expensive tho.
Sep 24, 2008 | 10:10 AM
deffo not available from ford anymore, my m8 tried and had to go the expensive route using mountune ones.
steve
Sep 24, 2008 | 10:13 AM
However they aren't really needed, unless you are running a high comp engine with big boost.
Sep 24, 2008 | 11:08 AM
Mad Matt
Hi,
188 £ a set on Burton Power !!!!!!!!
Sep 24, 2008 | 11:11 AM
I seem to recall there are less expensive alternatives being used - I think Markk mentioned them a while ago, from a zetec maybe ?
Sep 24, 2008 | 11:41 AM
as above, available from Mountune or Burtons
off topic slightly, but how good does Claude's aka 2001ode Sapphire look in the pic. It looks hard as nails!
what's the spec Claude?
Sep 24, 2008 | 12:21 PM
the 4x4 pickup pipe has oil spray jets in it...do these not do a good enough job then?
Dan
Sep 24, 2008 | 01:35 PM
SillyFezzaMk1
Dan
Hi,
Original pickup oil spray is good, but it is for a engine project with an dry sump system, and original oil pump is off.
Regards.
Claude
Sep 24, 2008 | 01:49 PM
LHD220Turbo
It's a track car 2wd.
Engine is 377 hp at 5890 rpm. and 1,8 bar, 403 injectors, L6 and MSD chip, T38 turbo, 3" Mongoose, AH intercooler, BD10 in and exh, Bilstein coil over grA front and rear, 410 and 400 lbs front and rear springs, adjustable TCA and compression struts, 3,92 with Quaiffe LSD rear axle, front brakes 315 x 28 mm. discs with AP racing calipers, rear brakes 4wd discs and calipers.
Claude
May 6, 2009 | 01:28 PM
2001ode
Hi,
share an info:
bmw z3 1.9 ltr ones can be used as well
cost 10 eur per piece
May 6, 2009 | 02:30 PM
My friend just got a block done by montune. Slightly different way it is machined etc but same idea
gambo08
Feb 4, 2016 10:49 PM
Oct 1, 2015 02:00 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fordmad!
Sep 29, 2015 07:03 PM
