Suspension with 17"s
Old Sep 23, 2008 | 11:04 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Cool Suspension with 17"s
Whats best drop when running 17"s?would standard ride height look ok?
Old Sep 23, 2008 | 11:57 PM
T28 RST's Avatar
T28 RST
Ok then
-25mm
Old Sep 24, 2008 | 05:16 AM
gus's Avatar
gus
mine was only 15mm i think
had a bit of stereo gear in the back so this weighed it down a bit
Old Sep 24, 2008 | 05:06 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
if u left it std height on 17s it will look like a 4X4,need to drop it a bit
Old Sep 25, 2008 | 12:15 AM
RSMK4TURBO's Avatar
RSMK4TURBO
What best -25mm springs to get then?
Old Sep 25, 2008 | 06:29 AM
robj20's Avatar
robj20
Im going to be putting the koni adj kit on mine, £390 from this place.
http://www.autotintdesign.com
Old Sep 25, 2008 | 12:11 PM
S2Dan's Avatar
S2Dan
Dont go any lower the 25mm mate, will look ok and still handle alright.
Any lower and your run into trouble with the arches probably. Thats if your not intending to mess about with the arches that is!
Old Sep 25, 2008 | 11:19 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Ive got new apex dampers and springs on at min but springs are to low i think they are -60mm as it hits exhaust on speed humps with the standard 15"s on,ive got some 17"s in storage which id like but on.What make -25mm spring kits are available,cheers.
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
