are modified pistons any good?
Old Nov 10, 2004 | 04:50 PM
the strut brace's Avatar
the strut brace
Default are modified pistons any good?
i am goin to send my standard 4x4 pistons to steve scott to get em machined
(valve cut outs for bd14 , and pocketed for low comp )
some people are sayin that this is a stupid idea and they will not last 2 minutes running greys t34 etc at high boost, stu will be live mapping it so i am thinkin that it WILL be ok if it is set up to the level of live mapping as pistons give up when the car runs lean etc etc , is this bollocks ?will they be ok if its all set up perfect or will they fuck up???
also my crank will have been machined for the second time, will this be ok or is the crank no good for 370ish bhp if its been reground twice???
Old Nov 10, 2004 | 04:53 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
are they mahls????????? if so yes they are fine and also stu can get it done
Old Nov 10, 2004 | 04:56 PM
the strut brace
no, they are ks ,or summit, think its klous schmit or something like that
Old Nov 10, 2004 | 04:57 PM
the strut brace
then again he may be a german porn star
Rs Gus's Avatar
Rs Gus
dont use em mate mahles or nuffink
Old Nov 10, 2004 | 05:01 PM
the strut brace
bollocks
Old Nov 10, 2004 | 05:07 PM
leesrs240's Avatar
leesrs240
They sound as dodgy as gary gliter
Old Nov 10, 2004 | 05:09 PM
ImaRacing 700's Avatar
ImaRacing 700
You have to remember its not the piston that fails if its proper mapped!!!!Although they will melt quicker if you develop a fueling fault!
Crank will be fine also!
Old Nov 10, 2004 | 06:22 PM
Turbo lag's Avatar
Turbo lag
who are you getting your bd 14 from strut brace because I need one as well.
Dave.
Old Nov 11, 2004 | 08:52 PM
Turbo lag's Avatar
Turbo lag
Up for the Strut Brace
Old Nov 11, 2004 | 09:11 PM
Jim Galbally's Avatar
Jim Galbally
phil, pistons dont ONLY fail due to det and running lean (ie melting) they can fail in other ways too (for example them being too weak and literally shattering)
markk
Dec 2, 2021 06:59 PM
3i Jim
Nov 20, 2015 05:12 AM
KW-rscos
11
Aug 31, 2015 01:51 PM
Escortdriver1
Aug 31, 2015 11:19 AM
ekjim
Aug 17, 2015 08:57 PM
