Suspension help
Old Sep 23, 2008 | 07:59 PM
godzilla's Avatar
godzilla
Default Suspension help
Both front lower wishbones on my car need replacing.... is this a difficult job, any tips??
The car is an Escort MK6
Old Sep 24, 2008 | 04:08 AM
stevecossy's Avatar
stevecossy
Hi mate, its prob best and easiest to replace the whole wishbone, and they are not that expensive if ya get em from a motor factors.
Think last time i got some they was about £26 a side and good enough quality for normal car.
The bolts/ nuts going up can often be pretty rusted but will come.
Good luck. Steve
Old Sep 24, 2008 | 09:47 AM
mark2's Avatar
mark2
hi fella is the car lowered if so you will knacker the new ones in a short time as i have found
as when you lower the car buy say 40mm the angle at which the car sits puts stress to the bush in a direction they are not suited to work at properly so they wear quicker
and i know through the problems i had on mine so i got a new set of new wishbones and fitted spherical bushes and uprated ones where needed the company i got mine from was deflex and at the time they had just only finished testing them so i bought a set and fitted them, can be difficult to remove the old ones speacialy the inner one but outter one i used a socket and a vise for inner one i used a knife heated up red hot and cut around the hole and cleaned them up with a dremmel or if you want use a blow torch to burn the rubber away but i dont advise it unless you know what you are doing
i had gone through 3 pairs of wishbone in a year before fitted the deflex ones and never ever replaced them again
and the car was tight at the front with none of that swaying as the old wishbones start to wear
you dont need to buy new wishbones to do this you can if you want i only did as i needed the car on the road at all times so done the bushes in my spare time and once done an hour to fit both sides then off for the tracking tobe done which you will have to have done after fitting new wishbones
if i remeber rightly the new spherical ones work out cheaper than new wishbones so if the car is lowered i would go this route as its cheaper in the long run
mark2
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
