what does the phase sensor do on a Cozzie?
Old Sep 23, 2008 | 06:44 PM
davidnormanuk's Avatar
davidnormanuk
Default what does the phase sensor do on a Cozzie?
I have just replaced my phase sensor on my Ecos as the car wouldn't start with it connected but now it starts fine but misfires when coming onto boost. Is there a way of testing it? also what does it do?
Dave
Old Sep 23, 2008 | 07:04 PM
Jay,'s Avatar
Jay,
Sponsor
irrc it tels the injectors what cylinder to fire needs to gapped crrectly
Old Sep 23, 2008 | 07:06 PM
Jim Galbally's Avatar
Jim Galbally
it has to be gapped correctly
Old Sep 23, 2008 | 07:12 PM
davidnormanuk
I have been advised to gap it to .25 is this correct?
Old Sep 23, 2008 | 08:21 PM
DazC's Avatar
DazC
It tells the ECU what cylinder is next to fire. It's for 720 degree engine syncronisation to allow sequential injection instead of batch fired/semi sequential.
Old Sep 23, 2008 | 08:30 PM
marco polo's Avatar
marco polo
so whats the ideal setting for the phase sensor because i have just changed mine
Old Sep 23, 2008 | 08:37 PM
bud-weis's Avatar
bud-weis
Football Cwazy
I seem to remember it being 0.3mm....and the CPS should be 0.6mm.
but my memory can be bad
Old Sep 23, 2008 | 08:39 PM
CraigoScott's Avatar
CraigoScott
it senses phases! badoooom tish!
Old Sep 23, 2008 | 10:27 PM
Stu @ M Developments's Avatar
PassionFords Creator
Its a cam sensor and i bet you connected it backwards. Red wire goes on left pin.
Old Sep 24, 2008 | 05:19 AM
As said needed if sequential injection, the red wire as said goes on nearest pin to the phase sensor, the body plug electrical connector is marked with + and - as well, but very tiny markings.
Old Sep 24, 2008 | 05:24 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
remember when i went to grove after my rebuild and mark said in a cockney twang...."Ooo tha fackin' ell fitted this cant"..............
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
