poly bushes
Old Sep 23, 2008 | 06:11 PM
cossiejim's Avatar
cossiejim
Default poly bushes
hi there i want to poly bush my s2 . how hard is it to do? and where is the best place to buy them from ?
Old Sep 23, 2008 | 08:12 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i done mine on my s2 when doing my resto, the back is harder than the front, the only prob you will have will be gettin the old fuckers off, i used a blow torch and a hammer to get my old ones off. the new ones just press in. i went for deflex there ok, but they didnt come labeled, they have a shop on ebay, type in flo-flex, 100 quid for a car set
if you want powerflex the best on the market you looking around 250 for a car set i think cant remember these are a better bush than the deflex ones.
Old Sep 23, 2008 | 08:17 PM
RAT8OY's Avatar
RAT8OY
Powerflex are a lot better than the others and I have tried then all. If its a car you are just playing with and needs new bushes then cheaper ones will be fine and offer a good improvement.
If its a minty mint keeper then spend the money and go for the powerflex!
Old Sep 23, 2008 | 08:20 PM
stevenebm's Avatar
stevenebm
post whore
defo go powerflex.i changed my deflex for them and found them better.
Old Sep 24, 2008 | 06:38 AM
Antti O's Avatar
Antti O
I need also new bushes for my pretty standard s2 turbo.
Can i use normal rubber bushes, or do you recommend deflex or powerflex?
Suspension will be koni adjustables & lesjöfors springs. (koni sport kit)
power approx 200-220hp.
And if you recommend polyurethanes, why?
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
