Speaking of none connected wires....
image 76 77 78 79 on http://s354.photobucket.com/albums/r412/KEVNOIZE/
1st three are the same connection was dangaling near the dipstick, dunno what the last 1 is.
Chances are then the temp sensor/bracket is missing from your engine. It should be located/bolted to the same location as the auxillary air valve under the intake manifold.
Mark RS
Oct 12, 2015 06:01 AM
