Heater blower motor problem
Old Sep 22, 2008 | 05:01 PM
Johnny Knoxville's Avatar
Johnny Knoxville
Default Heater blower motor problem
Blower motor doesn't work, tried about 3 second hand motors but still no joy?
I think it must be a wiring problem? so just want to know what are the 3 wires on the blow?
Want to know witch is witch and what it what?
Old Sep 22, 2008 | 05:21 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
u said the 3 wires,wht about the earth?
try the switch also as its easy to change!
Old Sep 22, 2008 | 05:26 PM
Johnny Knoxville
The Earth is ok
But what are the others?
Ok one is a switch 12v, one is a permanent 12v i think and whats the other one?
Old Sep 22, 2008 | 05:55 PM
brett_'s Avatar
brett_
my heater stoped work and it was the re-lay mate
brett
Old Sep 22, 2008 | 06:31 PM
Johnny Knoxville
Fitted a new relay and tried 2 others i had laying around
Old Sep 23, 2008 | 09:04 PM
Johnny Knoxville
anyone?
Old Sep 23, 2008 | 10:13 PM
L3 COS's Avatar
L3 COS
hi, just looked in wiring diagram for you (series2) the black and red wire is the power from the fuse box,it runs from the fuse to the switch,then out the switch to the blower,check that first. fuse 11 is the heater blower.
Old Sep 24, 2008 | 06:37 AM
OLDSKOOLRYAN's Avatar
OLDSKOOLRYAN
had this problem myself, ended up being dodgy connections in the fuse box.
Old Oct 28, 2009 | 06:03 PM
paulospug's Avatar
paulospug
RS Doer!!!!
Bit of an old forum I know, but having similar probs with mine. Should there be power at the plug which goes onto the blower motor? there is none at mine even when turned on. None at the variator switch for fan speed either. Where is the relay for it on the car please? I changed the blower thinking it was that but - NO! Refuse to buy another one lol.
Thanks.
Chas
Oct 5, 2015 07:13 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Flatlinedan
Sep 18, 2015 12:41 PM
marky_g
Sep 12, 2015 04:26 PM
dojj
Sep 8, 2015 08:31 AM
