A few small problems....
Old Sep 22, 2008 | 06:08 AM
VEEDUBBED's Avatar
VEEDUBBED
Default A few small problems....
Ok guys,
I have finally finished my turboed Vw corrado but a few small problems
have come up,nothing drastic.
1.when lifting off the accelerator pedal i've got no over-run cut off
anymore,on my wideband (PLX-R-500) the gauge stays on 14.5AFR,it should go open circuit as the injectors would be shut.
Using the cossy L8 Pectal ecu i have this problem,but before i had the
Pectal i was using an L8 off a delta evo.,as soon as you lifted the gauge went off the scale,meaning that fuel cut off worked.
2.Every now and then and only on a hot engine,the revs remain at around 2000rpm,as if the choke was jammed on,give the gas pedal a few stabs
and normally it clears its self.
Obviosly, if the idle valve is disconnected i don't have this problem but i get others
3.i've managed to find a rolling road here in Rome but i'm worried that
the tuner won't be able to access the Pectal software,when mapping
a Pectal super 8 system what's needed?.
Thanks for any suggestions
Andrew.
Old Sep 22, 2008 | 01:22 PM
R7BKR's Avatar
R7BKR
Maybe you should try these guys.
http://the-corrado.net/forum/home.php
Probably better placed to help you than a FORD forum.
Good luck, I hope you find what you need.
Old Sep 22, 2008 | 03:42 PM
VEEDUBBED's Avatar
VEEDUBBED
I'm already on there mate,my engines is fitted with the Pectal super 8 injection system that was fitted to a Ford sierra 4x4 cossy.
Anyway,i've been for a 50 km drive and noticed that at operating temp. the overrun fuel cut-off works.
I'll run in the motor then look into the other problems.
fordrallycar
Sep 30, 2015 07:57 PM
Fudgey
21
Sep 30, 2015 06:19 PM
youngben
Sep 27, 2015 09:37 PM
timsrs
22
Sep 24, 2015 08:14 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
