thermostate housing
Old Sep 21, 2008 | 05:13 PM
rst230bhp's Avatar
rst230bhp
Default thermostate housing
Hi all just a quick question.
i took my thermostat housing off, refitted it and there is water leaking from around it. I take it there should be a gasket between the housing and head.
are these available from any motor parts shop or will i need to visit ford.
thanks
Old Sep 21, 2008 | 05:17 PM
project rs's Avatar
project rs
you can get them at most motor factors or use some blue hylamar(not sure on spelling) around the edges instead
Old Sep 21, 2008 | 05:22 PM
rst230bhp's Avatar
rst230bhp
Thanks mate will get a new gasket tomorow
Old Sep 21, 2008 | 05:36 PM
addiction's Avatar
addiction
get a new gasket and use some blue hylomar on it! do not just use the hylomar without a gasket!!!
Old Sep 30, 2008 | 04:34 PM
zoober's Avatar
zoober
new thermostat with kit ( spring clip and gasket) is 3.50 from my local motor factor
Old Sep 30, 2008 | 05:43 PM
studabear's Avatar
studabear
or u can even buy some gasket paper for about a quid and make 1 up, its a bit of a pain but not bad if ur stuck
fordrallycar
Sep 30, 2015 07:57 PM
