frst running probs!!
Old Sep 21, 2008 | 04:36 PM
jd"rst"'s Avatar
jd"rst"
Question frst running probs!!
hi to everyone,ive got an escort xr3i with a fiesta rs turbo engine fitted running on ofac management.here goes its running lumpy and misfireing on idle and kangaroos when driving up to 2000 revs,ive changed plugs and leads also co pot and idle valve and no joy,i also cut pin 2 to edis module and extended the wiring for the idle control valve,to be honest im stuck now so any help would be appreciated!!!!
Old Sep 21, 2008 | 06:16 PM
crazycage's Avatar
crazycage
have a look at the coil pack plug there always f*cked on the fiesta turbo for some reason, and see if the map sensor pipe is split .
Old Sep 21, 2008 | 06:21 PM
jammy86's Avatar
jammy86
Yeah, as above check electrical connetors for corroded pins on the MAP and EDIS. Give them a blast of WD40 while your at it.
Is this a full throttle or part throttle?
JAmes.
Old Sep 21, 2008 | 08:50 PM
Turbo-Beal's Avatar
Turbo-Beal
Have you got the ht leads around the right way?
Old Sep 25, 2008 | 10:35 AM
martinmilne's Avatar
martinmilne
up up as i got the problem aswell
dombanks
Sep 21, 2015 08:38 PM
gcfcos
88
Sep 15, 2015 03:48 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
