Escort GTI switching 3-4 cylinders and misrifing!! URGENT HELP
Hi brought this GTI a week ago been playing up from day1 starting with misfiring, and kangerooing on acceleration, so far i ave changed the Following
New plugs
Tried coil Pack
Fuel filter
Injector cleaner in the fuel
Compression test ( all Normal)
Still o change and is now switching from 3-4 cyliners and is currently stuck on 3 cylinders, But if left overnight and started up cold it will start on 4 but then goes back on to 3 if you go for a drive (30 mins)
When the car is on 4 it misfires and kangerroos when on load
Has been on snap on diagnostic machine No fault codes where found. Thought to be a fueling problem as fuel pressure was checked and is a bit low could possible be blocked injector but i lost what to do next!!!!
Any help would be great thanks.
: wall:
New plugs
Tried coil Pack
Fuel filter
: wall:
