Help please
Old Nov 10, 2004 | 09:57 AM
huntingdon_orion's Avatar
huntingdon_orion
Default Help please
Hello i have just got my 1st erst about 3 weeks ago and now she is playing up ok here we go it will not run under 2000rpm as it stalls i was doin a 16mile run in the car down the a1 got to my mates house left the car for about 30mins came back out to go home and it would not start
Can anyone help me thanx for your time ppl
Old Nov 10, 2004 | 10:31 AM
adamS2RST's Avatar
adamS2RST
IT could be a number of things mate, how old is the engine and what sorta condition / spec? It is hard to say what it could be, have you checked all the obvious things? May well be best to take it to a tuner and make sure all is ok fueling / timing wise etc.
hth
Old Nov 10, 2004 | 10:40 AM
huntingdon_orion
Its standed mate all it has is a zorst and filter its done 125k so its been about its had
Dizzy cap
And arm
Leads
Plugs
Fuel filter (needed one )
Did have dump valve but took that off today
Old Nov 10, 2004 | 10:44 AM
adamS2RST's Avatar
adamS2RST
Hmm, looks like uve changed a few bits which could cause it, have you had the timing checked? I would personally take it to a tuners to get it setup and checked on the machine fueling wise etc. they will help
Old Nov 10, 2004 | 11:37 AM
mattbibs's Avatar
mattbibs
any immobilizers or security devices??
Old Nov 10, 2004 | 03:03 PM
lamar69er's Avatar
lamar69er
check all the boost pipes are tight, if theres an air leak it will try and stall or not start. Also check the dizzy out, sometimes the internals in the dizzy can brake down and cause ur motor to not start or randomly cut out, but I wouldnt of thought the dizzy would have altered which revs it will not cut out, most likely a boost pipe!
Old Nov 11, 2004 | 11:18 AM
huntingdon_orion
Thanks to you all for your input i found the prob today it was a boost pipe
Thanks again
chris
Old Nov 12, 2004 | 01:55 PM
lamar69er's Avatar
lamar69er
Happy for you m8!
nice and cheap fix!
Its a whole new learning curve owning a RS!
