It runs!!! Now what!!
Old Sep 19, 2008 | 10:17 AM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Default It runs!!! Now what!!
Ok.. I've changed coolant temp sensor, act sensor, phase sensor, lambda sensor, de-mulitiplug'd it and the car still behaves like a fckn kangaroo when it hits 4000rpm! What the hell is next? Starts and drives fine..
Old Sep 19, 2008 | 10:26 AM
Dan16v's Avatar
Dan16v
map sensor?
Old Sep 19, 2008 | 10:34 AM
El Grand Tomismola's Avatar
El Grand Tomismola
Checked all your Vac hoses on the car.
Mine popped one off the inlet manifold and it started driving like that.
Also check your throttle position sensor on the throttle body too, that maybe having an adverse cause?
Old Sep 19, 2008 | 10:37 AM
tore_tj's Avatar
tore_tj
Cossie Paranoia
map is new. gonna check the throttle body and vac hoses. Thanks.
Old Sep 19, 2008 | 10:46 AM
R5COS's Avatar
R5COS
dizzy cap if it Big turbo maybe
Old Sep 19, 2008 | 10:50 AM
AlexD's Avatar
AlexD
Post Miester !
have you checked the boost level ?? might be a ht lead breaking down or arching.
Old Sep 19, 2008 | 01:10 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
it's big turbo. should I turn down the boost and see if it changes?
Old Sep 19, 2008 | 03:10 PM
AlexD's Avatar
AlexD
Post Miester !
Worth a try...... 1st.. If mine ever cuts out i go for the boost level 1st, then the
plugs, then the leads and dizzy cap.
Old Sep 19, 2008 | 03:19 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
well I'm running only a wee bit over 1bar on greens and msd chip atm so guess it's not that.
Old Sep 19, 2008 | 05:47 PM
paul16v's Avatar
paul16v
Monte 087
Check/cange your alternator? i know it sounds silly but ive seen a few problems similar too yours cured buy this.
Old Sep 19, 2008 | 06:36 PM
JHS's Avatar
JHS
Measure the voltage before even considering changing it though, its not that cheap.
Old Oct 21, 2008 | 06:12 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Well.
Some news:
Was feeling a bit flush so forked out for a wasted spark conversion by msd. After some idiot ( me!!) managed to solder like an ass the car wouldn't start. After discovering the "professional" work it started fine.
Noticed the phase sensor plug was fitted the wrong way around when checking all the damn sensors. Don't blame me it was like that when I got it.
Well.. went out in the car and after letting it get warm full throttle in second gear. Pulled almost to the limiter then a small judder. Tried third. Judders when it hits 5k-6k. So it's out of "limp home mode". But what the hell?
Plugs or what? didn't boost more than 1,3-1,5 bar so shouldn't be boost cut.
Getting a bit tired now..
Old Oct 21, 2008 | 06:18 PM
THE RADMAN's Avatar
THE RADMAN
what plug gap are you running?
Old Oct 21, 2008 | 06:30 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Old Oct 21, 2008 | 07:01 PM
Dave Henshall's Avatar
Dave Henshall
0.75 with coilpack - and what plugs, 071C's? should be ok - are the screw on tops tight on the plugs.? had mine come loose and cause this.
Old Oct 21, 2008 | 07:23 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
no idea what plugs. they came with the car and the guy who sold it claimed they were new... Going to check what you have said. Is there any other reason this can happen? So I know what's next if it isn't the plugs..
Old Oct 21, 2008 | 10:02 PM
vinnya77's Avatar
vinnya77
Mine done a similar thing, it turned out to be the loom plugs on the N/S/F wing cut them out, untill I could afford for a new loom to be made.
Old Oct 22, 2008 | 08:38 AM
tore_tj's Avatar
tore_tj
Cossie Paranoia
First thing I did to the car
Old Oct 22, 2008 | 08:44 AM
Gary F's Avatar
Gary F
Try a new set of plugs mate
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
