Focus RS Brakes on Escort Cosworth?
Hi Everyone!
I was wondering, do Focus RS (type1) brakes (brembo 320mm) fit on the hub from an Escort Cosworth?
Is it a straight bolt-on job, or not (and what do you have to change?)
Thanks!
Cheers,
Bjorn
Thanks!
Cheers,
Bjorn
I'm putting these on my escos, will be using custom brackets and 300mm disc's so they fit under grp a 16"s.
Will try st170 disc's to see if the offset is anygood. Then maybe bell's if there no good.
And They will be on a rwd set up so off set maybe different?? will let you know how it goes
i have put honda intergra dc5 4 pot brembos on my 2wd cossie hubs with a 330mm disc, and i made up some custom brackets on the mill.
the whole lot cost just over 400 euros!! way better than about 1200 sterling which is the usal price for a similar new setup!
will try and get some pics
