lowering springs
Old Sep 15, 2008 | 08:30 PM
16vzetec's Avatar
16vzetec
Default lowering springs
can anyone remember who makes progressive front lowering springs for the mk4?
like in my siggy pic on the back of my car.
progressive meaning close coils at one end than far appart at the other end.
Old Sep 15, 2008 | 10:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I found out today that my G-Max have gone like this after 4000 miles! The top 4 coils are sitting one on top of another (actually touching/resting)and my wheels now rub when i go over a bump! LOL Cheap shit!
Not any help to you mate but though it ironic!
Old Sep 16, 2008 | 04:57 PM
16vzetec's Avatar
16vzetec
no mate they are supposed to be like that, the rears are for sure bit im after the fronts like that
Old Sep 16, 2008 | 09:51 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Are they really??
Whats the point in having the top coils if they all act as one? May as well be a solid peice of tubing until halfway down! lol
It was stood up for about 6 months just got it back on the road and now when i go over bumps or corner sharply they rub really badly!!!
Old Sep 16, 2008 | 10:17 PM
Jimmyc's Avatar
Jimmyc
Are they really??
For better comfort at lower speeds and better handling at higher speeds IIRC
Old Sep 16, 2008 | 10:22 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I can understand that if there was a smaller gap between the top 4 coils and a larger gap between the bottom ones, but there is NO gap at all between the top 4 they sit touching as one!! So only my bottom few coils are actualy doing anything!! It cant be right surely??!!
Old Sep 19, 2008 | 10:56 AM
16vzetec's Avatar
16vzetec
no what they do is off some softness and stability over bumps but still offers the hard part of the spring for cornering.
if you go over a hump in the road and the car lifts up then it will stretch the top coils out so when it comes back down it will come down smoother rather than coming down onto a stiff spring causing pogo effect.
my front end feels bit unstable at high speeds coz the springs are just hard all the way through
Old Sep 19, 2008 | 11:48 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Ah i see now!
Old Sep 19, 2008 | 12:52 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It's complete bollocks. Get some good linear springs.
Old Sep 21, 2008 | 04:38 PM
16vzetec's Avatar
16vzetec
oh right, explain then...............................
Old Sep 21, 2008 | 04:50 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
I don't need to explain, go look at some proper cars that handle well. Come back and tell me how many run progressive springs
Old Sep 21, 2008 | 05:23 PM
project rs's Avatar
project rs
try re-installing some standard rs springs again with your uprated shocks and see how that feels and work from that
Old Sep 22, 2008 | 08:20 PM
16vzetec's Avatar
16vzetec
whats your car then? what have you got suspension wise as you seem to know so much
Old Sep 23, 2008 | 06:33 PM
16vzetec's Avatar
16vzetec
i thought i had found some, apex springs, but when they came through they were rears on front shocks!! so still looking for some
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
richierich1986
Sep 18, 2015 03:29 PM
Adam Graham
Sep 6, 2015 06:04 AM
