Is 1.6 air box the same as a 1.8 zetec escort
Hi i need to know whether a 1.6 air box is the same as a 1.8 on an escort.
i need to know about the mounting and the pipes ect
Due to getting rid off shitty K&N filter because car running funny
Any help would be grately appreciated
I had a '96 1.8 Si and I wanted a spare airbox to drill for a K&N panel filter. The 1.8's have a bulbous rectangular air box whereas the 1.6's I came across had a triangular shaped top. If that makes sense.
at my local breakers i found the 1.8 top half air box and a hole 1.6 airbox surpose could join the to together to make 1? wot pipes conect to the standard air? mant thanks
Leeeroy... you had two different setups, obviously an early built 96 with the mk5 airbox and piping over the rocker cover and silver efi inlet
as opposoed to the 96 onwards with the black plastic inlet and piping accross the rear of the bay.
if you get the same model then the airbox is the same for 1.6/1.8
