MFI to EFI fuel pump? Also rear Brake bias hanger thing.
Old Sep 15, 2008 | 03:49 PM
muz's Avatar
muz
Wye Valley Hardcore
Default MFI to EFI fuel pump? Also rear Brake bias hanger thing.
I've had a search but cant seem to find the answer. I'm going from MFI to Cossie Management on my S2 but need to know if I need to change the Fuel pump ? I know the S2 is an external fuel pump, but I've got a Cossie in tank pump from my last Fiesta, could I use that or would it be an uprated external jobbie I need?
Also as I'm doing un underside resto can I get rid of the ford bias valve thing for the rear discs and fit an aftermarket one just to neaten things up and save painting an re-fitting? I'm fitting rear discs and re brake lining the car anyway.
Old Sep 15, 2008 | 04:22 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
for the fuel pump im sure if u get a EFI escort fuel tank u can use the cossie pump?not 100% sure tho,better off just getting a decent replacement of wht u got,less hasssle!
if u just re pipe it thn u can loose the bias crap valve,but IMO rear discs are a unsafe and are crap,some argree some disagree tho on tht 1
Old Sep 15, 2008 | 07:36 PM
zvhturbo29rs's Avatar
zvhturbo29rs
Default ZVH
I Run Rs Turbo Tank With Group A Cossie Fuel Pump On My Zvh,at 300bhp And Works Well. I Had Rear Discs On Mine And Found Them Realy Bad.back End All Over The Place.
original
Apr 28, 2026 05:20 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
