mk2 fiesta suspension
ive just bought a mk2 fiesta and as a bit of a newbie to the ford scene dont know what people would suggest for them. as in springs and shocks or coilovers, best makes in terms of value for money etc. so if anyone can point in the right direction it would help a lot, or tell me what they have up for offer.
cheers
Ant
cheers
Ant
coilovers all the way, they're awesome, much better than regular shocks and springs.
i have gaz gha coilovers and paid Ł420 for a full set, dampening is adjustable all round. The rear comes with stiff lowered springs uprated shocks, the front is fully hight adjustable however between 25mm and 80mm at least.
i believe AVO do coilovers which are of similar quality and spec but i opted for gaz's as i knew more about them and had seen xr2's with them fitted.
i would highly recommend gaz ones over cheaper alternatives (if they exist).
Gaz coilovers if your budget allows you, I used to have adjustable spaxs which where good for road use but going to be getting some Gaz coilovers as going to use my Mk2 on track.
Have a look on www.xrtwo.com as think there is a group buying going on for Gaz coilovers
Brian
Brian
SMILER258
Sep 28, 2015 09:04 AM
