Clearing last of the cossie parts
Polybushed rear beam complete with good diff, shafts, arms, 4x4 anti roll bar, was painted last year but needs a paint again, (has no brakes), did have new bearings when put together £215
Cossie door and wing strips all straight in good condiotion £50
Amal valve on stainless bracket £20
Front subframe with crossmember, Track arms and anti roll bar, all polybushed £50
2wd Head 138.6 comes with valves but 4 need replacing, also has set of lifters only done 1500 miles £220
205 bottom end, was rebuilt about 30k ago, complete with pistons, crank, rods in good condition, has 2wd sump fitted and complete with engine arms, modine, dizzy £400
2wd Coilovers, they have rusted so need freeing off, they are Gaz coilovers and done about 5k in 2 years, but seem to have rusted quite bad on the threads £200
Used Ahmed springs bought off here but never fitted £60
4x4 Inlet plenim complete £40
2wd exhaust Manifold £40
2wd Crank Pully £40
AP 6 paddle clutch standard cover, done 2K £125
Magnacor leads £40
4x4 rear calipers, £70
2wd Crank Pully £40
Magnacor leads £40
Thanasis
Sep 7, 2015 07:33 PM
