Roof
Old Sep 12, 2008 | 06:55 PM
bloopeta's Avatar
bloopeta
Default Roof
I have the usual rust bubbles coming through behind sunroof. I was thinking about replacing the roof skin to totally eliminate it, but my question is-
Should I replace it with a solid non sunroof roof skin?? as it seems to be the sunroof that causes the problem, and if I did, would it de-value the car and make it less desirable??? its a 1990 S2
Old Sep 12, 2008 | 07:54 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
My opinion: no and yes.
Don't replace it with a non-sunroof panel as it will devalue the car.
If you replace the panel with a very good condition item then it should last a good time before any new signs of corrosion appear and by then you will prob have moved on to something else.
Old Sep 12, 2008 | 08:04 PM
bloopeta's Avatar
bloopeta
how many people have just repaired there original roof skin and how long has it lasted before its come back through???
Old Sep 12, 2008 | 08:22 PM
bazza250's Avatar
bazza250
Default roof
i have been told 16months roughly with wkend use but i suppose you have to take other things into account.just having mine resprayed so i hope its a bit longer!!!!
Old Sep 12, 2008 | 10:13 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
i had mine done 3 years ago and its not come through yet, in some light you can just see small areas of paint the size of pin heads starting to show but ive only noticed it as ive kept an eye on it. im currently having it done again but this time while the sunroof is out im treating inbetween the roof skin and sunroof tray and then fully painting it all inside then clear waxoiling too.
also i recommend whenever the roof gets wet open the sunroof to give it a good airing to try to dry as much of the moisture as possible.
dave
Old Sep 13, 2008 | 12:02 AM
RSMK4TURBO's Avatar
RSMK4TURBO
In june i had mine treated by lead filling,then it was painted and waxoiled all over inside of roof,hopefully that should keep the rust at bay for a few years.I was also told that filling and repainting wouldnt last long at all, hence why i paid the extra to have it lead loaded.
So far im very happy with it.
Old Sep 13, 2008 | 07:18 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Lead filled or welded is the way to go over fill & skim. Will last longer and give a better finish.
Old Sep 13, 2008 | 07:20 AM
gus's Avatar
gus
im gonna be doing away with my sunroof completly
and the metal skin
carbon is my way forward
Old Sep 13, 2008 | 10:53 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I fixed mine.
Old Sep 13, 2008 | 12:15 PM
gus's Avatar
gus
well..............
Old Sep 13, 2008 | 02:46 PM
Christian and Beccy
#1 in Spelling Club
Originally Posted by gus
well..............
Well, what?
Old Sep 13, 2008 | 05:51 PM
Turbo-Beal's Avatar
Turbo-Beal
Has anyone thought about gettting a carbon roof fitted as another option?. Cut off the old rotton roof and refix and bond on a nice new carbon one. Just a thought
Old Sep 13, 2008 | 06:21 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
^ Read 4 replies above yours
Also check out a resto topic by a user called Twins, subject E*DAN
Old Sep 13, 2008 | 08:39 PM
Christian and Beccy
#1 in Spelling Club
Yes, but the RST roof design doesn't lend itself to a decent carbon conversion in my opinion. Twins encountered the problem of having a join at the top of the A-Pillar and have to make covers for the A-Pillars to help make that look right.
Personally, I don't much like carbon, so it's not an option for me.
A piece of steel plate and some Stikaflex/screws fixed mine nicely.
Old Sep 13, 2008 | 09:33 PM
craigos's Avatar
craigos
wierd how no company has made a roof skin they would sell well,hard to find a rs t with a good roof,thought about cuting out the rot in my old1 and sinking in a plate roof would warp bad and need alot of filler,think 1 prob is alot of rsts have had water leaks over the years etc and with the heaters on etc it rises,and sits on the cold roof
Old Sep 13, 2008 | 09:35 PM
craigos's Avatar
craigos
shame nightmare to repair sold mine in the end the rest of thecar was like new,id put a none sunroof roof on ,depends i guess how long you plan on keeping it
Old Sep 14, 2008 | 07:54 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Yes, you're right. The company who are doing Gus's are discussing ways of creating the A-pillars during construction I think - I know it was mentioned on his topic before but don't know whether he's pursuing it further.
A.t.p
Sep 29, 2015 05:04 PM
oldskooldanrst
Sep 27, 2015 04:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
Neil Clark
Sep 8, 2015 07:06 PM
