Light Relays Probs!!
Old Sep 11, 2008 | 08:14 PM
JamesSeries1Turbo's Avatar
JamesSeries1Turbo
Default Light Relays Probs!!
Hi all,
I had problems with my dipped beams. Found problem being the relay in fusebox changed went out next night and it cut off a turned lights off then on and no probs then they completely went. Changed relay again now fine. I think it frying the relays any suggestions? loose earth or something?
Old Sep 11, 2008 | 08:34 PM
Brian's Avatar
Brian
Mine used to do this i got a small screw driver and tweaked the contacts in the fuse box its self but after a while they stopped working again so i re run some new wire from the bottom of the fuse box to inside the car and fitted some new relays and it worked fine
Brian
Old Sep 12, 2008 | 10:00 AM
JamesSeries1Turbo
Hey thanks mate I will try this see what happens pain in the bollocks lol
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
IainRS1700T
Sep 25, 2015 06:44 AM
gcfcos
88
Sep 15, 2015 03:48 PM
