drilling cosworth cam cover
Old Sep 9, 2008 | 05:12 PM
proboscus's Avatar
proboscus
Default drilling cosworth cam cover
i have drilled my cam cover today ready for connecting to a separator.i have drilled it in the back right hand corner as you look from the front of the car 9just at the end of the word cosworth) will the engine be ok just braething from there or will i need to drill a hole on the other side of the cover above the other cam also.
Old Sep 9, 2008 | 05:33 PM
Will be fine just the one, unless mental bhp, a lot say this one is not needed/bad idea, some say good.
Old Sep 10, 2008 | 04:17 AM
stevecossy's Avatar
stevecossy
As tab says just the 1 needed in cover, Graham goode says its not needed but also many people av it with no probs.
I guess/hope your also breathing from the block as your question sounds like ya only using top cover.
Good luck. steve
Old Sep 10, 2008 | 08:29 PM
proboscus's Avatar
proboscus
yeah its also going to be breathing from the block and has the drain back to the sump .i am using the original drain port that the kidney box connected to is that below the oil level does anybody know?
jessie_rs
11
Jun 3, 2019 04:57 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
Aug 14, 2015 07:29 AM
M K
Aug 12, 2015 06:57 PM
